Complex & Real Differentiability ... Remmert, Section 2, Ch 1
4 replies · 3K views
Math Amateur
MHB
I am reading Reinhold Remmert's book "Theory of Complex Functions" ...
I am focused on Chapter 1: Complex-Differential Calculus ... and in particular on Section 2: Complex and Real Differentiability ... ... ...
I need help in order to fully understand the relationship between complex and real differentiability ... ...
Remmert's section on complex and real differentiability reads as follows:
In the above text from Remmert, we read the following ... ... just below 1. Characterization of complex-differentiable functions ... ...
" ... ... If ##f : D \to C## is complex-differentiable at ##c## then ...##\displaystyle \lim_{ h \to 0 } \frac{ f(c + h ) - f(c) - f\, ' (c) h }{ h} = 0##From this and (1) it follows immediately that complex-differentiable mappings are real differentiable and have ##\mathbb{C}##-linear differentials ... ...
Can someone please explain (formally and rigorously) how/why
(i) it follows from the limit immediately above and (1) that complex-differentiable mappings are real differentiable ... ...
(ii) it follows from the limit immediately above and (1) that complex-differentiable mappings have ##\mathbb{C}##-linear differentials ... ...(***NOTE: I suspect the answer to (i) is that the form of the two limits is essentially the same ... although I'm concerned about the presence of norms in one and not the other ... and also that we can identify ##\mathbb{C}## with ##\mathbb{R}^2## as a vector space ... is that correct?)Help will be appreciated ...
Peter
Physics Forum readers of the above post may benefit from access to Remmert's section defining R-linear and C-linear mappings ... so I am providing access to that text ... as follows:
Hope that helps ...
Peter
  • Remmert - 1 - Complex and Real Differentiability - Section 2, Ch. 1  - PART 1 ... .png
  • Remmert - 2 - Complex and Real Differentiability - Section 2, Ch. 1  - PART 2 ... .png
  • Remmert - 3 - Complex and Real Differentiability - Section 2, Ch. 1  - PART 3 ... .png
  • Remmert - 1 - R-linear and C-linear Mappings, Ch. 0, Section 1.2 ... PART 1 .png
  • Remmert - 2 - R-linear and C-linear Mappings, Ch. 0, Section 1.2 ... PART 2 .png
It follows, because we have any complex ##h## approaching zero, and we are thus allowed to restrict ourselves to real paths to zero, which still gives the same condition, so complex differentiability implies real differentialbility.
We have the differential ##f\,'(c)## which acts via multiplication on the direction ##h##, and multiplication ##h \longmapsto f\,'(c)\cdot h## is ##\mathbb{C}-##linear in its variable ##h##. (Remember my comment about the Jacobi matrix in the previous thread.)
Yes. Real is a subcase of complex.
This doesn't make a difference.
\lim_{ h \to 0 } \frac{ f(c + h ) - f(c) - f\, ' (c) h }{ h} = 0 \Longleftrightarrow \lim_{ h \to 0 } \frac{ f(c + h ) - f(c) - f\, ' (c) h }{ ||h||} \cdot \frac{||h||}{h}= \lim_{ h \to 0 } \frac{ f(c + h ) - f(c) - f\, ' (c) h }{ ||h||} \cdot z = 0 \Longleftrightarrow \lim_{ h \to 0 } \frac{ f(c + h ) - f(c) - f\, ' (c) h }{ ||h||} =0
$$ with a complex number ##z \in \mathbb{C}## of norm ##1##.
... and also that we can identify ##\mathbb{C}## with ##\mathbb{R}^2## as a [real] vector space ... is that correct?)
Yes, with the strong and loud emphasis on "as a real vector space". However, we have the complex numbers here as a field and a complex vector space, which are more than just a real plane, which is why complex differentiation is more - in the sense of stronger, resp. stricter - than real differentiation. With ##(\alpha\cdot i) \cdot (\beta \cdot i) = -\alpha \beta## we get a possibility to change between the dimensions: imaginary ##\to ## real. A rule which we do not have in real vector spaces, where we cannot just switch from one dimension (##x-##axis) to the other (##y-##axis) by some scalar multiplication.
Thanks fresh_42 ...
Reflecting on what you have written ...
But ... just a clarification ...
You write:
" ... ... It follows, because we have any complex ##h## approaching zero, and we are thus allowed to restrict ourselves to real paths to zero, which still gives the same condition, so complex differentiability implies real differentiability. ... ... "
Can you please justify why we are allowed to restrict ourselves to real paths to zero ... I thought we had to be able to approach zero along all paths ... can you please clarify ...Thanks again for your help ...
Peter
We want to show that ##f(c+h)-f(c) = f\,'(c)\cdot h + ||h||\cdot E_c(h)## holds for the real variable ##h## approaching zero. (I've used your previous notation as it is within one line.) What we have is, that ##f(c+h)-f(c) = f\,'(c)\cdot h + ||h||\cdot E_c(h)## holds for the complex variable ##h## approaching zero; that means, for all complex paths ##p: [0,1] \longrightarrow \mathbb{C}## approaching zero, e.g. ##p(t)=h \cdot (1-t)## or ##p(t) = \sin((1-t) \cdot |h|)## or whatever. Now if we only consider those paths among all allowed, which are real, i.e. ##p([0,1])\subseteq \mathbb{R}## we still have ##f(c+h)-f(c) = f\,'(c)\cdot h + ||h||\cdot E_c(h)## which is real differentiabilty. It also shows, that the converse direction does not hold: If we had real differentiability, we wouldn't have any knowledge yet about what's going on along complex paths to zero.
The complex derivative is complex linear by definition since it is defined to be multiplication by the complex number ##f'(c)##.
As Fresh_42 explained, a complex linear function is real linear since real numbers are complex numbers.
Given that it is real linear, your definition of real differentiable is immediately satisfied by taking the limit of the norm of
##\displaystyle \frac{ f(c + h ) - f(c) - f\, ' (c) h }{ h}## since if this goes to zero its norm must as well.
