Components of a Plane of Separation Problem
4 replies · 1K views
LCSphysicist
Be a particle with mass M and velocity v1 in a space with potential energy U1, it passes from this space to another with potential energy U2. What is the final direction of motion?
\n
I have no idea how to solve this problem. The solution says that the component parallel to the plane of separation is conserved, i am not sure why. Seems to me that in the problem was assumed a special field, but not a generic field.
I can't be fully rigorous here but i think the particle will experience a force upon it and this force will be towards the direction of change of the potential energy, i.e perpendicular to the plane of separation. (because it is ##\vec{F}=\nabla U##.)
Hence the component parallel to the plane of separation has no forces , so this component of the velocity is conserved.
OBS: There is a negative sign, ##\vec{F}=-\nabla U##
But see, i think you agree with me there is fields that can produce a force parallel to the plane of separation. Seems the question is imagining a field perpendicular to the plane.
If there is such field, then the potential energy wouldn't be constant ##U_1## in one space and ##U_2## in the other space, the potential energy will also vary along the direction parallel to the plane of separation.
This field is a consequence that the potential energy varies (from U_1 to U_2) in the direction perpendicular to the plane of separation.
