How Do You Calculate the Velocity of a Stone in Projectile Motion?
To calculate the velocity of a stone thrown horizontally at 5 meters per second after 0.2 seconds, one must consider both horizontal and vertical components of motion. The horizontal velocity remains constant at 5 m/s, while the vertical velocity can be calculated using the formula v = gt, where g is the acceleration due to gravity (9.8 m/s²) and t is time (0.2 s). This results in a vertical velocity of approximately 1.96 m/s downward. The overall velocity can then be determined using the Pythagorean theorem to combine the horizontal and vertical components. Understanding these principles is essential for solving projectile motion problems effectively.
The Vitruvian Man
Astone is thrown horizontally with an initial velocity of 5 metres per second. What is the magntude and direction of its velocity 0.2s later? Take the acceleration of free fall to be 9.8 metres per second squared and ignore friction.
This question, I find it very confusing I do not know why..I have no clue.[/B]
Welcome to the forum. Please note the forum rules in the homeworks section require you to make an attempt at a solution so we can see where you are going wrong.
