Composing functions that are conformal
  • Thread starter Thread starter d2j2003
    Functions
12 replies · 3K views
d2j2003
let f and g be conformal analytic functions with the range of f a subset of the domain of g. Show that the composition g(f(z)) is also conformal.
Well I know that if the function is conformal it is 1-1, analytic, and its derivative is non zero. So I'm thinking that I would need to show that since f'(z)≠0 and g'(z)≠0 then (g(f(z))'≠0 and then show that since f and g are analytic, g(f(z)) is also analytic. Then the composition will be both analytic and its derivative will not be zero so it will be conformal. Am I working in the right direction?
That's one way to do it. The other way is to just go straight with the definition and show that g(f(z)) preserves angles
Is it possible to show, in general, that g(f(z)) preserves angles? I thought we would have to have actual functions defined for that..
How would I prove the derivative part of this? I know that (g(f(z)))'=g'(f(z))*f'(z) and obviously f' is not zero but I'm not sure how to show with certainty that g'(f(z)) is not zero...
You are given that "the range of f a subset of the domain of g".
Let P, Q, and R be three points such that angle PQR has measure [itex]\theta[/itex]. Then, since f is conformal, P'=f(P), Q'=f(Q), and R'= f(R) are three points such that angle P'Q'R' has measure [itex]\theta[/itex]. And, since g is conformal, P''= g(P'), Q''= g(Q'), and R''= g(R') are three points such that ...
Such that the angle P''Q''R'' is θ meaning that the composition is angle preserving. right?
can we say that since the range f(z) is in the domain of g then g(f(z)) is basically g(z)? and then it is non zero from there?
f being conformal doesn't imply that. The 'angle preserving' in conformal refers to the angles between intersecting curves. Not to angles between points. That only works if f maps lines to lines.
g' is nonzero on its domain. f(z) is in that domain. I wouldn't say 'g(f(z)) is basically g(z)', that's not very true.
well when we say g(z), that z includes f(z) since the range of f is a subset of the domain of g... ie. g(z) takes values from its domain, which includes f(z).. right?
Right. Just say f(z) is in the domain of g. Don't say g(f(z)) is the same as g(z).
ok, got it. Thanks for your help
