Composing functions with substitution u = 2x² + 10
5 replies · 2K views
christian0710
Hi I'm a bit confused about some mathematical notation
If i write
f(x)=(2x^2 + 10)^4
And i define
u= 2x^2 +10
u^4 = f(x)
Would it then be correct to write
f(u)= u^4
Or would i get
f(u)= 2(u)^2 +10 = (2(2x^2 +10)+10)^2
Should i define u^4 = f(x) first? Would it then be correct?
My book writes that if u is a function of x then then you can put u into x and get the following.
∫f(u)du = F(g(x))
So I want to make sure I'm assuming correctly.
A last question: If you define a function f to have the equation f(x) = 2x is it then true that the variable y=f(x) differs from f, because f is a function (not a number) and y is a number?
So when we take f(x)= (1+2x)^2 and call u=(1+2x) then it would be wrong to write f=u^2 because f is already defined as a function (not a value?)
So writing ∫fdx or∫fdf would just be plain wrong?
If i write
f(x)=(2x^2 + 10)^4
And i define
u= 2x^2 +10
u^4 = f(x)
f(u)= u^4
Or would i get
∫f(u)du = F(g(x))
You should keep the form of the function f(x). Like so.
f(x)=(2x^2 + 10)^4
f(u)=(2u^2 + 10)^4
And so on. That is, you should think of the content of the () in f(x) as a placeholder.
If you want to have u as some function of x then you can define a different function to account for this. Like so.
u(x) = 2x^2 + 10
F(u) = u^4
F(u(x)) = u(x)^4 = (2x^2+10)^4 = f(x)
Or to use a different example, consider the trig function sin(u). If you plot sin(u) as a function of u for u between 0 and ##2\pi## you get a nice sine wave. If you then think about u being a function of x, say u(x) = x^2, then you have sin(u(x)) = sin(x^2). If you plot this function as a function of x for ##x = 0## to ##\sqrt{ 2\pi}## it will still go through the same values, but the shape will be different. You should try this to see what I mean.
Yes. y is a number because f(x) is a number. However, even though y is a number and not a function, it's still correct to say that y is a function of x, because the value of y is determined by the value of x. You can also say that about f(x). f is a function, but f(x) is a number and a function of x. But don't say that f is a function of x. That wouldn't make sense.
Yes, this would be wrong. You can write ##f(x)=u^2##, but not ##f=u^2##. However, if you define a function g by g(t)=1+2t for all real numbers t, then you can write ##f=g^2##. This is based on the following definition of the product of two functions: (fg)(x)=f(x)g(x) for all real numbers x. Then we can define the notation ##g^2## by ##g^2=gg##. So ##g^2(x)=(gg)(x)=g(x)g(x)=g(x)^2## for all real numbers x.
Yes. I think ∫f is an acceptable alternative to the standard ∫f(x)dx, but I still don't recommend using it, because people aren't used to seeing it.
That would not be wrong but just have different meanings. The point is that you have tell others what you concern, that is, ##dx## and ##df## in this case.
Yes. The notation ##\int f## is acceptable and ##\int f(x)dx## is acceptable, but not ##\int f dx##. The notation ##\int fdf## is acceptable, but that is the same as ##\int xdx##, which is not what you mean.
