Compton’s experiment vs ordinary mirror
  • Context: High School
  • Thread starter Thread starter exmarine
    Experiment Mirror
The discussion centers around the differences in photon interactions between Compton scattering in a carbon target and the reflection of light from an ordinary mirror. Participants explore the implications of energy and momentum transfer in these scenarios, particularly in relation to the behavior of light and its effects on materials.
  • One participant notes that Compton's experiment involves measuring changes in wavelengths of scattered photons and correlating this with energy and momentum transfer to electrons.
  • Another participant suggests that the lack of red-shift in photons reflected from mirrors may indicate that no significant energy and momentum are imparted to the electrons in the mirror, raising questions about the differences in interactions.
  • It is proposed that the interaction of lower energy photons with a mirror involves arrays of atoms, which may not cause energy level changes in individual atoms, leading to a different outcome compared to Compton scattering.
  • A participant raises a question about whether the discussed effect could explain the rotation of a Crookes radiometer, indicating a potential link between the two phenomena.
  • Another participant speculates on the expected direction of rotation of the radiometer based on the reflection of light, contrasting it with observed behavior and expressing uncertainty about the underlying mechanisms.
  • Some participants discuss guidelines related to thread topics and the relevance of off-topic questions, with references to external resources provided for further reading.
  • A request for information about experiments with Crookes radiometers under varying air pressure conditions is made, indicating ongoing curiosity about the topic.
Participants express various viewpoints regarding the interactions of light with mirrors versus Compton scattering, with no consensus reached on the implications for the Crookes radiometer or the nature of momentum transfer in these cases.
Participants acknowledge the complexity of the interactions involved and the potential for differing interpretations based on experimental conditions and material properties.
exmarine
Compton hit the electrons in a carbon target with x-rays and measured the changes in the wavelengths of the scattered photons versus their deflected angle. He correlated that with the energy and momentum the incident photon gave to the electron.
My question is why does this not happen in mirrors? AFAIK there is no red-shift in the much lower energy photons reflected from an ordinary mirror. Is no energy and momentum given to the electrons in the mirror? What is the difference in these cases?
As you've already said, the waves in light have much lower energy than X-rays, which also gives them a larger wavelength, so the scale of their interaction is much larger, involving arrays of atoms, and for materials suitable for a mirror the energy is not enough to cause energy level changes in individual atoms which would absorb energy.
So the light bounces off the mirror as a whole, which does cause a very tiny change in momentum and could in theory give the mirror as a whole some kinetic energy eventually. The effect is far too small to be significant in normal cases, but is the basis of "solar sails" which may be used in future as a means of propelling space probes.
Do you think this effect is responsible for the rotation of a Crookes radiometer, or is that view controversial?
What direction would this turn a radiometer?
In what direction does a radiometer actually turn?
I suppose you would expect the white sides to retreat, because the radiation is reflected, not absorbed, imparting more momentum to the vane. I think this is opposite to what is observed, which at least proves that I don't know what is going on.
BTW, that was an innocent question. Which guideline did I violate?
If you're referring to the guidelines link in Vanadium 50's signature line, that's just for information.
You did somewhat change the subject of the thread, which could be considered to be against the "hijacking" guideline, but it wasn't far off topic.
In addition to the above "light mill" article, the Wikipedia article on Crookes radiometer contains some useful information.
Thanks for the references.
