Concave Spherical Mirrors: Object Position for Inverted and Enlarged Image?
6 replies · 9K views
roam
A concave spherical mirror has a radius of curvature of magnitude 27.1 cm. Determine the object position for which the resulting image is inverted and larger than the object by a factor of 4.00.
Mirror equation in terms of focal length: 1/p + 1/q = 1/f
I'm not getting the correct answer for this question. Here's what I've done so far:
First we find the focal length
[tex]f=\frac{R}{2} \implies \frac{27.1}{2}=13.55 \ cm[/tex]
[tex]M = \frac{-q}{p}=4 \implies q=-4p[/tex]
Substituting in
[tex]\frac{1}{p} - \frac{1}{4p} = \frac{1}{13.55}[/tex]
[tex]\frac{3}{4p} = \frac{1}{13.55} \implies p =10.162[/tex]
I don't know why the answer is wrong. I know that image is inverted when Magnification is negative. Here it is not -ve because the questions says "larger" so I took it as positive...
Discussion
Substituting in
What are you trying to find? You haven't said.
Oops. The question I was trying to ask was:
You are having trouble with the minus signs.
There are two conventions out there one says magnification is -p/q the other says it is p/q
one of them has 1/p + 1/q = 1/r , the other has 1/p - 1/q = 1/r
make everything positive, and work on a positive magnification meaning inverted.
So, are you saying I should have used M=q/p so that q=4p? Because I am using the +ve equation 1/p+1/q=1/f.
YES! It worked. Thanks for clarifying this, I REALLY appreciate all your help.
