Concentric circles are parallel?
211 replies · 50K views · last reply
Mark44 said:
I agree with HallsofIvy. If you have two straight lines that are parallel (no intersection points) and you translate one of them so that it coincides with the other line, then the two lines intersect at every point.
No doubt it's a problem with your command of English. "To intersect" does not necessarily mean that the lines have to cross at some nonzero angle.
The superposition straight line, their included angle is zero mutually, but intersects the straight line, their included angle is not zero. Therefore is different.
In the attached figure is an animation, explained that anything is the superposition, any intersection, they are different.
  • Two parallel green line segments slanting upward to the right against a black background, one above and offset from the other.
Mark44 said:
The animation clearly shows that when one line is superimposed on another, there are an infinite number of intersection points.
there are an infinite number of intersection points. ???
a line is a set of infinite points sharing a value, a two dimensional continuum of those points
if a line has an infinite number of points, and another line merges with the first, then both have an infinite number of points, and an infinite number of intersection points
if you have two lengths of rope that are infinitely long, and place one on top of the other, then there are an infinite number of places you could stick a nail through both ropes o_O
Let's not use any analogies from real life, or we'll never hear the end of how the ropes can't be truly merged, only touching each other.
I thought that he would be able to reason that, since we're talking about plane geometry, a distinction in 3 dimensions can't be made, since it is a top-down view...
Mark44 said:
So you now agree with me and HallsofIvy?
No, I did not agree, I thought in the animation shows the superposition is the parallel one kind, but in animation intersection, is not is parallel.
:wink:
Actually, after the superposition straight line is a straight line, is two straight lines becomes a straight line, therefore I asked that the straight line is own and oneself is parallel.
The parallel essence is the distance maintains invariable, but is not the intersection does not intersect. .
Why? Because you say so?
Parallel is defined as two or more lines that maintain a constant distance between each other and as such, they don't intersect.
Notice: two or more lines.
Actually, parallel was aims at two lines, the parallel essence was two line distances maintains invariable.
Parallel aims, a pair, a pair of line.
Yes, two distinct lines.
But the superposition line is two line special situations,
Two congruent triangles may superpose a triangle. Two straight lines are congruent, two straight lines may also superpose a straight line.
Do you realize you've nearly hit 150 posts and most - if not all of it - has consisted of crackpottery?
phya, geometry is one of those things where you should accept the ideas put forth by the people who created and developed it...the definitions have been argued about for thousands of years and conclusions have been reached based on logical arguments
if you really want to learn geometry, go pick up all three volumes of https://www.amazon.com/dp/0486600882/?tag=pfamazon01-20 and work through it; it explains all of the definitions and ideas in great detail
Yes, the Euclidean geometry already had over a thousand year history, but afterward presented the non-Euclidean geometry, this explained that the geometry is in the development.
2500 years, and Greek geometry is the first use of rigorous proof in science.
but afterward presented the non-European geometry,
Non-Euclidean or Non-European? Regardless, if you want to learn plane geometry, take my suggestion, a few hours of study will blow your mind.
Plane geometry is well understood lol.
You must acknowledge that parallel is the distance maintains invariable, because the distance has changed, therefore only will then intersect. The concentric circle and straight line parallel is similar, they are the distance maintain invariable. Whether you do acknowledge this point?
In Europe, the supposition we give human's definition are “the white skin biology”, afterward Columbus's ship to the Americas, the crews has discovered some living thing, is similar with the human, but their skin is the black, therefore the crews had the argument, the most people had thought that these living thing were not the human, because they did not conform to human's definition, most only might call them the kind of human biology, but the small number of people believed that these living thing were also the human, was only their skin's color is different.
Are we about the parallel line question argument are also so?
That's 100% wrong. Europeans have known of the swarthy races (subspecies) for a very long time. Aryan invasion of India? was at least 3,500 years ago.
If you don't want to actually study the nature of the things you're talking about, fine. But don't try to change standard definitions to suit your opinion when there is material available for you to study so you can understand why things are labeled as they are.
So all you're hoping in doing is that you'll make a contribution to mathematics somehow? You need a reputation first, and that is to know that specific topic inside out.
There is a reason we coined the term crackpot to describe those that suggest new crazy far out theories in science with little to no math ability or even a respectable knowledge in the topic at hand. If you just looked at all the crackpot theories in relativity...
And judging by some of your ideas, mainly that the absolute of a number is an "unsigned" number and not positive because that is being prejudice, then I can only suggest that you put your theories away in the basement, study the maths for many years to come - particularly geometry. It will give you the time to fully appreciate what the collective thinking of millions of mathematics over thousands of years have been able to produce - and once you're grown ripe in age and have a firm position in the understanding of modern geometry, take a look at those dusty old tomes again that you threw into the basement. See if those theories are still sound, and if they are, pursue them further with your new status of being a professional in that topic.
I was only said that if, but not really thought any discovery black skin's person.
Will discuss the issue in here not to know the parallel definition.
equivalent statements to the parallel postulate :
There exists a pair of straight lines that are at constant distance from each other.
Therefore a straight line own and oneself is also parallel, because in this case, the straight line and the straight line distance is zero.
At most one curve can be drawn through any point not on a given curve parallel to the given curve in a plane.
L1 and L2 whether still parallel?
In the analytic geometry,
Supposition
the straight line L1 equation is y=kx,
the straight line L2 equation is y=kx+c,
then L1∥L2 is parallel,
if reduces c, then still L1∥L2.
When c=0,
L1 and L2 are coincident lines,
