Graduate How Do Nested Conducting Loops Interact Electromagnetically?
This discussion focuses on the electromagnetic interactions of nested conducting loops with identical initial currents. The loops are perfectly conducting and elastic, allowing for growth or shrinkage while only experiencing electromagnetic forces. The primary challenge is understanding how induced currents and forces between the loops affect their configurations and energy minimization. The conversation emphasizes the importance of establishing equilibrium states through systematic equations, while noting that stable configurations may not exist due to the nature of the forces involved.
  • Understanding of electromagnetic theory, specifically the behavior of currents in conducting loops.
  • Familiarity with concepts of paramagnetism and diamagnetism.
  • Knowledge of equilibrium states in physical systems.
  • Basic skills in numerical simulation techniques for dynamic systems.
  • Explore the mathematical modeling of electromagnetic forces in nested conducting loops.
  • Learn about numerical methods for simulating dynamic systems, focusing on time-stepping techniques.
  • Investigate the principles of magnetic field interactions and their effects on induced currents.
  • Study the conditions for equilibrium in electromagnetic systems and the implications of energy minimization.
Physicists, electrical engineers, and researchers interested in electromagnetic theory and the dynamics of conducting materials in complex configurations.
bob012345
Hello,
As a heuristic tool for a complex problem, I'm trying to understand a series of nested conducting loops each with a initial identical current on it. These perfectly conducting loops are in the same plane each with that current in either direction. Each nested loop is perfectly conducting but also perfectly elastic, it can grow or shrink and only has electromagnetic forces.
Starting with one loop, we add another loop and try and figure out how the first loop changes and what the final configuration is that minimizes overall energy. They can merge into one loop or remain separate loops.
What my conceptual issues are is when we get beyond a couple loops and one has induced currents and forces between the loops. I just want to get a handle on a systematic process of understanding what one might call paramagnetic or diamagnetic forces, depending on whether they attract or repel for each new loop and how each new loop effects the previous loops.
The magnitude of starting currents in each loop is fixed but can be in either direction but once set for a loop doesn't change.
I just need hints at a systematic approach. Thanks.
Simulate it in small time steps? For a given configuration at a given time, you can determine the forces, and translate them to accelerations (or velocities if you like a lot of friction).
Thanks but I'm thinking of setting up an equation to determine the equilibrium situation. It's things like how the currents are reflected and induced (if that happens) that stump me. It's how to determine the forces that act. For example, I can see that the second loop will have a magnetic field that effects the first loop. Depending on the currents, it will either repel or attract. I assume circular symmetry. There must be an equal and opposite force on the other loop.
Technically you could have some induction if things are moving quickly, but not in the equilibrium state. For the equilibrium states you get static conditions, you can set up equations for the equilibrium and solve them. I would be surprised if there is a stable equilibrium at all. The outer loop should expand forever, or collapse until it hits an inner loop which then expands further to become an expanding outer loop.
Thanks. I agree with you although for simplicity I left out part of the problem that would stabilize the loops since I'm not looking for a complete solution yet. I agree about no induction at equilibrium. We could assume they are rigid for now and there will be induction as things work toward equilibrium each time we add a current loop but at equilibrium there could be stable currents that are reflections of the original currents induced during the period of change. We are adding energy each time we add a new current loop.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 20 ·
