How Do You Calculate Conditional Expectations in Probability Theory?
The discussion focuses on calculating conditional expectations in probability theory, specifically E(Y|x) and E(X|y) using a joint probability density function. The joint pdf is given as f(x,y) = 2 for the region defined by 0<x<y<1. Participants clarify the correct approach to finding the marginal pdf f(x) and the conditional pdf f(y|x), emphasizing the importance of integrating over the correct limits. The final solution for E(Y|x) is confirmed to be (1+x)/2 after resolving initial confusion regarding the calculations. The conversation highlights the significance of accurately defining the integration bounds in probability calculations.
Scootertaj
1. Let the joint pdf be f(x,y) = 2 ; 0<x<y<1 ; 0<y<1
Find E(Y|x) and E(X|y)
E(Y|x) = \int Y*f(y|x)dy
f(y|x) = f(x,y) / f(x)
f(x) = \int 2dy from 0 to y = 2y
f(y|x) = f(x,y)/f(x) = 1/2y
E(Y|x) = \int Y/2Y dy from x to 1 = \int 1/2 dy from x to 1
= -(x-1)/2
= (1-x)/2
The answer is supposed to be (1+x)/2
Your expression for f(x) is wrong. It should be a function of x, not of y. Try drawing a picture of the region where f(x,y) is nonzero. Then answer this question: for a fixed value of x, what values of y will give you a nonzero f(x,y)?
The only other way I can think of doing f(x) would be to integrate from 0 to 1 instead. f(x) is defined as the integral of the joint pdf in terms of y.
So, we could get integral(2dy) from x to 1?
Correct, from x to 1 (not as 0 to 1 as you wrote in the previous paragraph). Also be sure to state which values of x this is valid for.
That will give us 2(1-x) so f(y|x) = 1/(1-x)
I'm confused how this will give (1+x)/2 for E(y|x)
Just kidding I worked it out, thanks.
That's the answer I got. What integral are you calculating for E(y|x)?
[edit] Cool, I see you got it.
  • · Replies 18 ·
