gracy
- 2,486
- 83
I want to verify whether I am correct .As the title suggests It is about point where potential is zero (point other than infinity)
Note:x is distance of neutral point from charges
Firstly,I would like to ask
Is coordinate system necessarily be there
1) If there are two positive charges for the neutral point to exist one of them should have negative x,so that one of the two potentials becomes negative and the two potentials should have same magnitude so that they cancel each other.Right?
And in order to have negative x ,coordinate system must be present.
2)If there are two negative charges for the neutral point to exist one of them should have negative x,so that one of the two potentials becomes positive(negative sign of q and r would cancel each other) and the two potentials should have same magnitude so that they cancel each other.Right?
3)If there are two charges,one positive and the other negative ,then in this case for the neutral point to exist both of them (charges)should have positive x ,and the two potentials should have same magnitude so that they cancel each other.Right?
