Calculating Time to Melt 8.78kg of Ice in a Styrofoam Icebox
  • Thread starter Thread starter espnaddict014
    Conduction
The discussion focuses on calculating the time required to melt 8.78 kg of ice at 0°C in a sealed Styrofoam icebox with dimensions 27.2 cm x 35.7 cm x 51.2 cm and wall thickness of 1.20 cm. The heat transfer equation used is ΔQ/Δt = kA[(T1-T2)/l], where k is the thermal conductivity, A is the surface area, T1 is the outside temperature (30.9°C), and T2 is the ice temperature (0°C). The heat required to melt the ice is calculated using Q = m * L, with L being the latent heat of fusion (334 kJ/kg). The final calculations yield the time needed for the ice to melt based on the heat transfer rate.
  • Understanding of heat transfer principles, specifically conduction.
  • Familiarity with the latent heat of fusion for water (334 kJ/kg).
  • Basic knowledge of geometry for calculating surface area and volume.
  • Ability to convert units (e.g., cm to m).
  • Calculate the total surface area of the Styrofoam icebox for accurate heat transfer analysis.
  • Research the thermal conductivity values for various materials, including Styrofoam and air.
  • Explore the concept of phase changes in thermodynamics, particularly regarding melting and freezing.
  • Learn about the impact of insulation thickness on heat transfer rates in thermal systems.
Students in physics or engineering, thermal system designers, and anyone interested in practical applications of heat transfer principles.
espnaddict014
Approximately how long should it take 8.78 kg of ice at 0oC to melt when it is placed in a carefully sealed Styrofoam icebox of dimensions 27.2 cm x 35.7 cm x 51.2 cm whose walls are 1.20 cm thick? Assume that the conductivity of Styrofoam is double that of air and that the outside temperature is 30.9oC.
I'm trying to start with the equation:
delta Q/ delta t = kA* [(T1-T2)/l]
But I have a volume, and I guess I didn't know if V could replace A, but it doesn't seem like it should. Then even if it could, I would have calculated a J/s. And also, do i need to incorporate a phase change in this problem? Any help would be appreciated.
Work out the total surface area of the icebox. That is A. You are given the thermal conductivity, k and the thickness, l. Just plug in the numbers to give the rate of heat transfer. You should be able to work out the length of time needed to melt the ice from that.
AM
To calculate the time it takes for 8.78 kg of ice to melt, we can use the formula for heat transfer:
Q = m * L
Where Q is the heat required to melt the ice, m is the mass of ice, and L is the latent heat of fusion for water which is 334 kJ/kg.
First, we need to convert the dimensions of the icebox from cm to m:
27.2 cm = 0.272 m
35.7 cm = 0.357 m
51.2 cm = 0.512 m
Next, we can calculate the volume of the icebox:
V = l * w * h = (0.272 m)(0.357 m)(0.512 m) = 0.05 m^3
Since the walls of the icebox are 1.20 cm thick, we need to subtract this from the dimensions to get the volume of the actual space inside the icebox:
V' = (0.272 m - 0.024 m)(0.357 m - 0.024 m)(0.512 m - 0.024 m) = 0.04 m^3
Now, we can calculate the volume of ice:
Vice = 8.78 kg / 917 kg/m^3 = 0.0096 m^3
The remaining volume is filled with air, so we can calculate the mass of air:
mair = (0.04 m^3 - 0.0096 m^3) * 1.2 kg/m^3 = 0.039 kg
Next, we can calculate the heat required to melt the ice:
Q = (8.78 kg)(334 kJ/kg) = 2934.52 kJ
Now, we can use the formula for heat transfer to calculate the time it takes for the ice to melt:
Q/Δt = k*A*(T1-T2)/l
Where:
Q = heat required to melt the ice (2934.52 kJ)
k = thermal conductivity (double that of air, so we will use 0.04 W/mK)
A = surface area of the icebox (0.04 m^2)
T1 = outside temperature (30.9°C = 304.05 K)
T2 = initial temperature of ice (0°C = 273.15 K)
l = thickness
  • · Replies 17 ·
11K
  • · Replies 23 ·
