Undergrad Are the Two Equations for Push-Forwards in Differential Geometry Equivalent?
  • Thread starter Thread starter dyn
    Confused
The discussion centers on the equivalence of two equations for the push-forward of tangent vectors in differential geometry, specifically for a diffeomorphism Φ: M → N. The first equation, (Φ*v)f = v(Φ*f), is contrasted with the second equation, (Φ*v)f = (Φ-1)*v(Φ*f). The participants conclude that the second equation is correct, as it maintains consistency in the spaces involved, while the first equation leads to undefined terms. The confusion arises from the roles of the tangent vector v and the function f across the manifolds M and N.
  • Understanding of differential geometry concepts, specifically diffeomorphisms.
  • Familiarity with tangent vectors and their push-forward operations.
  • Knowledge of pullbacks and their definitions in the context of manifolds.
  • Basic grasp of scalar functions and their derivatives in manifold theory.
  • Study the properties of diffeomorphisms in differential geometry.
  • Learn about the definitions and applications of push-forward and pullback operations.
  • Explore the implications of vector fields in the context of manifolds.
  • Investigate the conditions under which a diffeomorphism is invertible.
Mathematicians, students of differential geometry, and anyone interested in the formal properties of manifolds and vector calculus.
dyn
Hi. For a diffeomorphism between 2 manifolds Φ : M → N with a tangent vector v in M I have the following equation for the push-forward of v
( Φ*v)f = v( Φ*f) where Φ* is the pull-back. I understand this equation but i have also come across the following equation for the push-forward
*v)f = (Φ-1)*v (Φ*f ) . Surely these 2 equations are not the same. I'm confused.
I assume that ##v## is a vector in a tangent space of ##M## and ##f## is a one-form in a cotangent space of ##N##.
Then the RHS of the second equation doesn't seem to make any sense. ##(\Phi^{-1})^*## needs as argument a one-form in the relevant cotangent space of ##M##, but what it is given ##v(\Phi^*f)##, which is a scalar. So the RHS is undefined - meaningless.
Where did you see that second formula? Perhaps it is a typo.
You can use the pullback of a one-form to define the pullback of an arbitrary p-form. For a 0-form this is rather uninteresting though so maybe not what was intended.
I'm fairly sure what's intended is that ##v## is a vector on ##M## and ##f## is a function on ##N##. The action of ##v## on ##f## (if they were both on ##M##, which they are not) is defined by
$$v(f) \equiv df (v)$$
(or alternatively, that's the definition of ##df##, depending on which notions you've decided are more fundamental).
If ##f## is a function on ##N## given by ##f : N \to \mathbb{R} ; y \mapsto f(y)## for ##y \in N##, then the pullback ##\Phi^* f : M \to \mathbb{R}## is defined, for ##x \in M##, via
$$(\Phi^* f)(x) \equiv f(\Phi(x))$$
Now, as for your confusion about the equations. ##\Phi_* v## should be a vector field living on ##N##, and hence ##(\Phi_* v)(f)## should be a function living on ##N##. However, in your first equation, ##v(\Phi^* f)## is clearly a function on ##M##, not ##N##. Therefore, it is your second equation which is correct:
$$(\Phi_* v)(f) \equiv (\Phi^{-1})^* (v(\Phi^* f))$$
because now both sides of the equation live on ##N##. One must use ##(\Phi^{-1})^*## rather than ##\Phi_*##, because functions out of a space (as ##f## is) must be pulled back rather than pushed forward.
An interesting question arises when perhaps ##\Phi^{-1}## doesn't exist (for example, when ##M## has smaller dimension than ##N##, and ##\Phi## is an embedding). In this case ##\Phi_* v## is not defined on all of ##N##, but only on the portion of ##N## on which ##\Phi## is invertible. That is, ##\Phi_* v## is only defined on the image of ##\Phi##.
Likes dyn
I suppose it depends on whether ##v## is a vector field or just a single vector in a single tangent space at point ##p\in M##. From the way the question is worded - not mentioning vector fields - I feel drawn to assume the latter.
In that case ##v(\Phi^* f)## is a scalar in the overarching field ##F##, being the directional derivative in direction ##v## of the scalar function ##(\Phi^* f):M\to F##, at point ##p##. The equation then asserts that that is equal to ##(\Phi_*v)f##, which is the directional derivative in direction ##\Phi_*v## of the scalar function ##f:N\to F##, at point ##\Phi(p)\in N##.
I don't know whether that equation is valid, but it is well-defined as an equality between two elements of the same field.
I think more context of the problem is needed to make a clear interpretation.
The vector v is a tangent vector in the manifold M. Of the 2 equations I quoted does one refer to a function in M and one refer to a function in N ? Do functions exist only in specific manifolds ?
I forgot to say ; thanks for all your replies.
Assuming that ##f## represents a function and not a one-form in this context, which seems likely, then both equations refer to both a function ##f## on ##N## and a function ##(\Phi^*f)## on ##M##. The latter is the 'pullback' of the former and, as Ben pointed out above, is defined by
$$(\Phi^*f)(p)=f(\Phi(p))$$
where ##p\in M##.
Likes dyn
  • · Replies 20 ·
  • · Replies 38 ·
  • · Replies 21 ·
  • · Replies 36 ·
