Confused with this proof for the Cauchy Schwarz inequality
The discussion centers on the proof of the Cauchy-Schwarz inequality, specifically the determination of the minimum value of the variable lambda (##\lambda##) in the context of the inner product. Participants clarify that the critical point derived from setting the derivative with respect to ##\lambda## is indeed a minimum, as the function exhibits no upper bound when ##|\lambda| \rightarrow \infty##. The conversation also touches on the relationship between ##\lambda## and its complex conjugate ##\lambda^*##, emphasizing the necessity of minimizing the inner product to achieve the proof's requirements.
  • Understanding of the Cauchy-Schwarz inequality
  • Familiarity with inner product spaces
  • Knowledge of calculus, particularly derivatives and critical points
  • Basic concepts of the Gram-Schmidt process
  • Study the derivation of the Cauchy-Schwarz inequality in detail
  • Explore the Gram-Schmidt process and its applications in vector spaces
  • Learn about the properties of inner products in complex vector spaces
  • Investigate the implications of critical points in optimization problems
Mathematicians, students studying linear algebra, and anyone interested in proofs related to inequalities and vector spaces will benefit from this discussion.
jaded2112
This might be a silly question but im honestly confused. In this proof, how was it concluded that, from setting the derivative with respect to lambda and finding the critical point, there is a minima at that point?
https://ibb.co/BnFGKwX
Im confused as finding the minimum value of lambda is an important part of the proof but it isn't clear to me that the critical point is a minimum
jaded2112 said:
Homework Statement:: This might be a silly question but I am honestly confused. In this proof, how was it concluded that, from setting the derivative with respect to lambda and finding the critical point, there is a minima at that point?
Relevant Equations:: https://ibb.co/BnFGKwX
It can't be a maximum, due to the behaviour of the function for large ##\lambda##.
That said, treating ##\lambda## and ##\lambda^*## as independent variables needs a bit of explanation!
Thanks for the reply.
Can you elaborate on why lambda can't be a maximum?
Also, i think lambda is the independent variable because it can be any complex valued number and minimising the inner product is an important part of the proof.
It doesn't matter if it is a minimum or maximum.
We have this inequality which holds for any ##\lambda##
$$0\leq (\phi,\phi)-\lambda(\phi,\psi)-\lambda^*(\psi,\phi)-\lambda\lambda^*(\psi,\psi)$$
Now suppose that I tell you to apply this inequality for ##\lambda=\frac{(\psi,\phi)}{(\psi,\psi)}##.
You will be able to infer what is asked for, that is the Cauchy-Schwarz inequality for the inner product, won't you?
But then you going to ask me how did I come up with this value of ##\lambda## won't you?
There is no maximum as the expression has no upper bound as ##|\lambda| \rightarrow \infty##. That's supposed to be so obvious that the author doesn't even mention it.
You're saying that ##\lambda^*## is independent of ##\lambda##? In the same way that ##x## is independent of ##y##. You can vary ##\lambda^*## without changing ##\lambda##?
There is a reason that works, but it definitely needs some explanation and without it the proof is very sketchy.
Note that, in general, just because a set of steps comes out with the right answer doesn't mean the steps are right.
@PeroK, @jaded2112 where do we use the fact that it is a minimum? I simply don't understand sorry, all it seems to me that we need is a proper value of ##\lambda## to apply the inequality.
You're right. To get the required result, you just need to set ##\lambda## equal to the required expression.
  • Wow
But then again why the value of ##\lambda## that makes that expression minimum (or maximum) with respect to ##\lambda^*## is the one that works? Sorry but I just don't get this.
See proof 3.
https://en.wikipedia.org/wiki/Cauchy–Schwarz_inequality
There's a neat geometrical view of why that ##\lambda## minimises the expression, which is related to the Gram-Schmidt process. You're taking off the amount of one vector that is contained in the other. That's not needed for the proof. That's another reason to distrust this proof as a bit sketchy - it gets the right answer, but what's being done is not justified.
PS I'm sure I've seen that minimisation argument used somewhere, but I can't remember where. Something more general that the C-S inequality.
PeroK said:
See proof 3.
Sorry the proof 3 in that wikipedia link just magically comes up with the value of lambda. Perhaps you meant to post another link? Gram-Schmidt process? How does that relate here?
You should be able to draw a diagram and see this for yourself (using real vectors for simplicity):
Let's start with two linearly independent vectors ##\vec u, \vec v##. You could draw ##\vec u## along the x-axis, say, and ##\vec v## somewhere in the first quadrant.
To minimise ##|\vec w| = |\vec u - \lambda \vec v|##, we want the vector ##\vec w## to be orthogonal to the vector ##\vec v##. This is exactly what we do in the Gram-Schmidt process: we want a linear combination of ##\vec u, \vec v## that is orthogonal to ##\vec v##.
And, to find ##\lambda## we can use: $$\vec v \cdot \vec w = \vec v \cdot (\vec u - \lambda \vec v) = \vec v \cdot \vec u - \lambda |\vec v|^2$$ And, if ## \vec v \cdot \vec w = 0##, then $$\lambda = \frac{\vec v \cdot \vec u}{|\vec v|^2}$$ And C-S falls out of this if we look at ##|\vec w|^2##, with the added result that equality occurs only if ##\vec u, \vec v## are linearly dependent.
  • · Replies 19 ·
