Clarifying the Confusion: Op Amp Gain in Non-Inverting Amplifier Circuits
The discussion centers on the confusion regarding the calculation of gain in non-inverting amplifier circuits. It highlights that the closed-loop gain is primarily determined by the resistor ratio (R1/R2) rather than the open-loop gain of the op-amp, which can be extremely high. While the open-loop gain is theoretically infinite, practical applications often use lower gains due to noise and other factors. Different op-amp models exist to cater to specific needs, such as low bias current or high-frequency performance. Ultimately, understanding the relationship between open-loop and closed-loop gain is crucial for accurate circuit design.
aesoph13442
According to my professor's model answer for an assignment, when we derive the transfer function of an op amp circuit, we have a "K" value, which is the open loop gain of the op amp (I am not 100% certain), multiplied to the op amp circuit (1+R1/R2 for non-inverting amplifier for example). I need to multiply the "open loop gain" with "close loop gain" in order to get the transfer function for a specific circuit. However, when I read the non-inverting amplifier section in "fundamental of microelectronics" by Ravazi, his explanation is in the following: "Interestingly, the voltage gain depends on only the ratio of the resistors; if R1 and R2
increase by 20%, R1/R2 remains constant." It's on page 358 for 2nd edition. I just wonder which version is correct.
Likes berkeman and aesoph13442
this is correct
watch this video
http://www.bing.com/videos/search?q...E950D0C45487CFCBDAEFE950D0C45487CFC&FORM=VIRE
Dave (not me) explains opamps very well :)
Dave
Thank you Dave! I have one more question. If the gain only depends on other components rather than the op amp itself, what is the point of having different models of op amp? I know some op amps are designed to remain a "normal" behavior in higher frequencies or have a larger bandwidth. But besides those reasons, what is the point of using a different model of op amp? Let's say I am plotting the bode plot of some transfer functions, some of them start at 0dB and some start at 60dB or a different value. The starting point depends on the constant coefficient of the transfer function. Does the op amp determine the value of the constant? Is it the open loop gain (gain of the op amp)?
You can rely on the resistor ratio to be an approximation to the gain of the op-amp-with-feedback only if the op-amp's open-loop gain far exceeds that. And as you say, if you want high closed-loop gain at higher frequencies then the op-amp itself must be able to deliver even higher gain at those higher frequencies. A good high frequency response equates to a snappy behavior with squarewaves.
Some op-amps are designed to draw very very low currents at the inputs so these will take almost no power from the signal source.
The open loop gain of any/all op-amps is very high, in theory, infinity, practically tho, 10's or 100's of 1000's, which for normal use is never needed.
10's or 100's or occasionally a few 1000 gain is the most ever used ( depending on requirements)
Why are there so many ?
Many reasons ... many of the earlier versions are still around they may have lower gain before noise becomes a problem
other newer ones have extremely low noise, high current handling output, higher working voltage etc
looking through different datasheets, you will be able to see the beneficial features some have over others
for some basic circuits where input bias currents etc are not critical to the op-amp or circuit operation beans that cheaper more basic op-amps can be used
Other circuits may call for high precision very low bias current leakage and so there are op-amps made for that purposeDave
aesoph13442 said:
I need to multiply the "open loop gain" with "close loop gain" in order to get the transfer function for a specific circuit. .
That`s definitely wrong. The following formula says everything (Aol=open-loop gain, k=feedback factor):
Closed-loop gain (non-inverting amplifier with k=R2/(R1+R2))
Acl
=Aol/(1+Aol*k)=1/(1/Aol+k).
For 1/Aol<<k we get Acl=1/k.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 33 ·
