Confusion about using the t table or z table for confidence intervals
In determining confidence intervals, the choice between using the t-table or z-table depends on whether the population standard deviation is known. In this case, since the standard deviation of the PCB concentration is known at 0.08 ppm, the z-distribution should be used despite the small sample size of 10. For the IQ scores of 18 students, the Student's t-distribution is appropriate because the standard deviation must be estimated from the sample. Understanding the difference between population parameters and sample statistics is crucial in statistical analysis. This clarification significantly aids in grasping the concepts of confidence intervals and standard deviation estimation.
Bill Nye Tho
Here's the question:
The PCB concentration of a fis hcaught in Lake Michigan was measured by a technique that is known to result in an error of measurement that is normally distributed with a standard deviation of .08 ppm. Suppose the results of 10 independent measurements of this fish are:
11.2, 12.4, 10.8, 11.6, 12.5, 10.1, 11.0, 12.2, 12.4, 10.6
Give a 95 percent interval for the PCB level of this fish.
So, I have a small sample size (10) and a normal distribution. I attempted to use the t-table for this solution but the solutions manual used the Z-distribution table. I can't figure out why.
We have a known standard deviation. It should probably be .8 ppm typo? So the confidence interval is
$$\bar{x}-Z_{.95/2}\frac{\sigma}{\sqrt{n}}<\mu<\bar{x}+Z_{.95/2}\frac{\sigma}{\sqrt{n}}$$
If the standard deviation is not know, we use the sample standard deviation s to estimate it and the Student's t-distribution
$$\bar{x}-t_{.95/2}\frac{s}{\sqrt{n}}<\mu<\bar{x}+t_{.95/2}\frac{s}{\sqrt{n}}$$
Thanks for the reply lurflurf!
That leads me to additional question. I'm given a data set of a sample of 18 students and their IQ scores. Why is the confidence interval for the mean IQ estimated with the Student's t-distribution. I can easily find the variance and the deviation from the data set.
What is the difference between finding the standard deviation myself and having it explicitly stated?
You can't find the standard deviation yourself. You CAN estimate the standard deviation using your sample.
The distinction between population parameters and sample statistics is very important. You won't get anywhere in statistics until you grasp this.
That just cleared up a whoooooole lot of this course for me.
Thanks for that!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • Poll Poll
9K
33K
  • · Replies 19 ·
18K
