Confusion on mechanics problem involving cart, blocks, and pulley
The discussion revolves around a mechanics problem involving a system of a cart, blocks, and a pulley. Participants are examining the accelerations of two masses, m_1 and m_2, and how these relate to the equations provided by the professor. There is confusion regarding the definitions of acceleration in different frames of reference and the implications of these definitions on the problem's setup.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants are questioning the professor's use of acceleration terms in the equations, particularly whether they are defined relative to the ground or the moving cart. There is also discussion about the implications of m_1's vertical movement and its effect on the horizontal acceleration of m_2.
Several participants are exploring different interpretations of the acceleration definitions and their consequences. Some have suggested that the solution provided by the professor may be incorrect based on their understanding of the forces involved. There is ongoing dialogue about the assumptions made regarding the movement of the masses and the forces acting on them.
Participants note that the problem may involve constraints such as the movement of m_1 being vertical only, which raises questions about the forces acting on the system. There are references to specific equations and conditions that may not have been fully accounted for in the professor's solution.
niko_niko
Initially, the system of objects shown in Figure P5.93 (see attached) is held motionless. The pulley and all surfaces and wheels are frictionless. Let the force F be zero and assume that ##m_1## can move only vertically. At the instant after the system of objects is released, find (a) the tension T in the string, (b) the acceleration of ##m_2##, (c) the acceleration of M, and (d) the acceleration of ##m_1##. (Note: The pulley accelerates along with the cart.)
[1] ##m_2 (a-A) = T##
[2] ##MA = T##
[3] ##m_1 a = m_1 g - T##
[Mentor Note -- Two threads on the same by the OP have been merged into one]
I'm having trouble understanding the solution my professor gave me, in particular, the accelerations of m_2 and m_1. When my professor solved for the acceleration of m_2, he used a as the acceleration but when I look at the second law equation for m_2 as shown in eqn. [1], it's a-A. Likewise, when he solved for the acceleration of m_1, he used a-A as the acceleration when according to eqn. [3], it says a. Is this just a simple error on his part or am I misunderstanding something?
I'm having trouble understanding the solution my professor gave me, in particular, the accelerations of ##m_2## and ##m_1##. When my professor solved for the acceleration of ##m_2##, he used ##a## as the acceleration but when I look at the second law equation for ##m_2## as shown in eqn. [1], it's ##a-A##. Likewise, when he solved for the acceleration of ##m_1##, he used ##a-A## as the acceleration when according to eqn. [3], it says ##a##. Is this just a simple error on his part or am I misunderstanding something?
niko_niko said:
Homework Statement: Initially, the system of objects shown in Figure P5.93 (see attached)
Where?
Is this the proper figure?
haruspex said:
Where?
Forgot to attach sorry. Here it is.
Yes, that is also what my professor showed me.
I assume that means vertically relative to M.
How did your professor define a, as acceleration in the ground frame or relative to M?
Well, looking at the second law equations he wrote, I would assume a is measured relative to the ground given that it took into account the acceleration A of the cart. But when he solved for the acceleration of ##m_2## for item (b) he seemed to only use a, as shown in the image below.
If a is the magnitude of the vertical component of the acceleration of the suspended mass then it is also the acceleration (to the right) of the top mass relative to the block. (Using the constancy of rope length.) If the acceleration of the block is A to the left then the top mass's acceleration to the right in the ground frame is a-A.
So in that case, the solution provided for (b) should be the acceleration for the hanging mass and not the top mass. Am I correct?
No. (b) asks for ##m_2##'s acceleration. Since it does not specify relative to the block M, you should take that as acceleration in the ground frame, a-A.
But in the solution provided for (b), my professor used a instead of a-A. Likewise, in (d) the acceleration for the hanging mass was a-A according to the solution.
Did your professor really write those 3 equations as they are written?
Yes. Those are the exact equations that were provided. For reference, I attached the solution my professor gave me containing those equations.
Let ##a_B## represent the acceleration of the large block in the positive x direction, and "a"represent the downward acceleration of m1. Then "a" is also the horizontal acceleration of m2 relative to M, and the absolute horizontal acceleration of m2 is ##(a_B+a)##. OK so far?
First, the solution shows I guessed wrongly about "m2 only moves vertically". It means that in the ground frame.
Given that, the expression found for ##a## is correct, but it is not the acceleration of the top block in the ground frame.
Looking now at the solution to (d), it seems the solver has become confused between the two masses, as you suspected. The answer to (d) should be the expression found for ##a## and the answer to (b) should be ##a-A##.
Hmm. Does the large block accelerate in the positive x direction? My assumption is that it should move to the left due to the force exerted by the rope.
In that case, ##a_B## would come out negative, right? Are you only looking at the case where F = 0?
That would be what I would imagine for the case of F=0, yes. Which means the acceleration of the top block should be a-a_B, right?
Assume the large block is accelerating to the left with ##{}^+\leftarrow##, what do you get for the sum of the forces on that block ( with mass ##M## )?
I'm just going to say it. I don't think the solution provided is correct. If ##m_1## can only move in the vertical direction it must be restricted by a track of some sort. That track is essential for providing the force that pulls ##m_1## along in the horizontal direction. As a direct consequence of Newtons 3rd there is a force that has not been accounted for acting on the large mass ##M## in the solution provided by the prof.
If F=0 and the cart is moving to the left, then m1 doesn't contact M.
A track is not required. Nor, according to the givens in the problem, can a track (attaching ##m_1## to ##M##) be present.
We are only asked for initial forces and accelerations. Initially, the only forces acting on ##m_1## are vertical. Accordingly, the initial acceleration of ##m_1## will be purely vertical. The proviso in the problem statement is not needed.
If, counterfactually, there were a track constraining ##m_1## to follow the face of ##M##, then, because ##M## accelerates leftward, so would ##m_1##. This would violate the givens of the problem statement which state that ##m_1## moves vertically only.
It would be possible for ##m_1## to be mounted on a vertical guide track anchored to the ground without violating the givens of the problem. This would not "pull ##m_1## along in the horizontal direction" since ##m_1## is stipulated not to move in the horizontal direction. However, since such a track would, at least initially, exert zero force on ##m_1##, it would be redundant.
I didn't catch this is to be solved at the instant of release. Skim reading gets me again.
Because of what I was missing above, I figured they meant it only moves vertically in the frame of reference of the cart.
Yes, at the instant the restraining forces are released, I agree.
Sorry, I thought the vertical motion constraint of ##m_1## was w.r.t. the cart. Also, I didn't see we were only to solve at the instant the system is freed.
niko_niko said:
It seems my question got duplicated. Could the moderators close the other thread: https://www.physicsforums.com/threa...-of-system-of-cart-blocks-and-pulley.1053967/
Rescuing this reply of mine from that other thread:
… the expression found for ##a## is correct, but it is not the acceleration of the top block in the ground frame.
niko_niko said:
...My assumption is that it should move to the left due to the force exerted by the rope.
It is important for you to visualize that is the x-component of T (the magnitude of the angled total force is greater than T), via the pulley and its support, what induces the big block to slide to the left.
The rope itself can only pull m2 and m1.
Seems reasonable to treat the block and pulley as a unit, so @niko_niko is correct to say that the force exerted by the rope causes its acceleration.
I am convinced that the solution to this problem has to be a mistake for the reason that the accelerations of the top block ##m_2## and the hanging block ##m_1## are simply inconsistent with each other. To reiterate, the solution in item (b) says that the acceleration of the top block is ##a## whereas the solution in item (d) says that the acceleration of the hanging block is ##a-A##. There is simply no conceivable way for the vertical acceleration of the hanging block to be ##a-A## if it was stated that the hanging block can only move in the vertical direction.
  • · Replies 22 ·
  • · Replies 30 ·
  • · Replies 29 ·
  • · Replies 33 ·
10K
