Homework Help: Confusion RLC circuit
  1. May 21, 2013 #1
    Hi i got this question ?
    [Broken]
    have to find Vr and VL
    so can i use this formula :
    VR = IR
    VL = I * XL???
    confuse ?? need help ??
    am i on right track?
  3. May 21, 2013 #2
    ehild
    Impedance is used for AC circuits, when the current and voltage have sinusoidal time dependence. Here the time dependence of the current is different from a sine function. Go back to the definition of the voltage across a capacitor (in terms of charge) and inductor (in terms of derivative of current).
    ehild
  4. May 22, 2013 #3
    so answer is 0.002 * (20/1) = 0.04 for Vl
    right?
  5. May 22, 2013 #4
    ehild
    ??? You have to show the time dependence of voltages. The answer is not a number.
    ehild
  6. May 22, 2013 #5
    whaaattt???
    are you kidding mee !!
    need help please !!!
  7. May 22, 2013 #6
    ehild
    I try to help and I am not kidding. Read the problem text, please.
    ehild
  8. May 22, 2013 #7
    yeah i know its time dependency .. this is the graph for voltage in inductor vs time in ms
    [Broken]
  9. May 22, 2013 #8
    ehild
    You sent the plot of voltage across the resistor. The shape is correct, but watch out the magnitude. The current is given in A (ampers) The resistance is 2Ω. What is the maximum voltage across the resistor?
    What about the inductor?
    ehild
  10. May 22, 2013 #9
    [Broken]
    Got it right?
  11. May 22, 2013 #10
    gneill
    Staff: Mentor
    No, your diagrams are not correct.
    Can you write the general expressions (definitions) relating voltage and current for a resistor and an inductor?
  12. May 22, 2013 #11
    ehild
    No. The maximum voltage for the resistor is about right now, but the shape is not. You remember Ohm's Law: The voltage across the resistor is U=IR, proportional to the current. The shape of the U(t) function follows the shape of I(t).
    As for the inductor, remember Faraday's law about induced emf in a coil and inductance. How was it defined?
    ehild
  13. May 22, 2013 #12
    I know deal with resistor but i have no clue about inductor
  14. May 22, 2013 #13
    ehild
    The voltage across the inductor is U=L(dI/dt) (it is proportional to the time derivative of the current). Determine the derivatives at the different sections and multiply by L.
    ehild
  15. May 22, 2013 #14
    Along with U=L(dI/dt) , We should point out that the voltage across the capacitor v = (1/C) integral (i(t)) and of course voltage across the resistor is v = IR. The plot of current is simple enough that taking the integral or the derivative is simple.
  16. May 22, 2013 #15
    I agree with you. If the graph is current against time then this is the voltage across the inductor for the first part of the graph AND the last part of the graph. This voltage will be constant over these time intervals.
    For the middle part it will be -0.04V.
    For the flat bits of the graph there is no change of current with time....what will the voltage across the inductor be ??
  17. May 22, 2013 #16
    ehild
    The current changes 2 A in 1 ms,( Edit:20 A in 1 ms) so the voltage on the inductor is not 0.04 V.
    ehild
  18. May 22, 2013 #17
    It looks to me like 20A in 1ms .....
  19. May 22, 2013 #18
    ehild
    I lost a zero, thanks. I edit the previous post. But still, UL is not right.
    ehild
  20. May 23, 2013 #19
    so it will be this graph right because di/dt is derivitve !!!
    [Broken]
  21. May 23, 2013 #20
    ehild
    Excellent! Good solution, nice picture. (Only the unit V is missing from the vertical axis.)
    ehild
  22. May 23, 2013 #21
    Yeah i solve the question but i forget how i did it and why is like that !!???
    :(:cry:
  23. May 23, 2013 #22
    ehild
    Go to post #13:smile:
    ehild
  24. May 23, 2013 #23
    gotchya for 1 ms liner becomes flat and than flat becomes no gradient follow on right?
  25. May 23, 2013 #24
    ehild
    The flat part has zero gradient so zero induced voltages.
    ehild
  26. May 23, 2013 #25
    Nice !!! thanks for all the help !!
Have something to add?
Draft saved Draft deleted
