Conservation of ang. momentum using Euler-Lag. Eqns (help ;-)
3 replies · 2K views
T-7
Hi,
I'm stuck on what I suspect is a really easy proof. I'd appreciate some rapid help!
For a trajectory with given initial position and velocity, we can always rotate the system of coordinates such that initially [tex]d\theta / dt = 0[/tex] and [tex]\theta= \pi/2[/tex] say, t = 0.
Using the Euler-Lagrange equations, show that [tex]\theta[/tex] remains at [tex]\pi/2[/tex] for all times t.
Having obtained the Lagrangian (L=mv^2/2 + U, rewriting v as [tex]\dot{r}^{2}+r^{2}(\dot{\phi}^{2}sin^{2}\theta + \dot{\theta}^{2})[/tex] in spherical coordinates, and taken partial derivatives with respect to [tex]\dot{\theta}[/tex] and [tex]\theta[/tex], and [tex]\phi[/tex] and [tex]\dot{\phi}[/tex], I have found the following relations (I think they're correct?)
[tex]d/dt [mr^2\dot{\theta}] = mr^2\dot{\phi^2}cos(\theta)sin(\theta)[/tex]
[tex]d/dt [mr^{2} \dot{\phi} sin^{2} (\theta)] = 0[/tex]
(There is a third expression, from the partial derivatives wrt. [tex]r[/tex] and [tex]\dot{r}[/tex], but I doubt it's relevant here.)
I'd be tempted to integrate both sides of the first to get an expression for [tex]\dot{\theta}[/tex], but that's where I become unstuck just now... I'm not sure how to integrate the RHS with respect to time, given what I know about the components. But presumably integration is going to be involved here, or the initial conditions would never come into play (?). I can deduce from the second that [tex]mr^{2} \dot{\phi} sin^{2} (\theta) = const = c[/tex], and so at t = 0 [tex]mr^{2} \dot{\phi} = c[/tex], but nothing more of interest seems to be following at the moment...
Incidentally, I take the geometrical meaning to be that the motion is confined to a plane orthogonal to L, ang. momentum is conserved.
Advice gratefully received (as soon as possible!) Many thanks :-)
The statement you are trying to prove is not true for any potencial energy U. Does the problem include something like U=U(r)?
Yep. :-)
If you put theta(t)=pi/2, then the equation is always true. I think this proves that theta must be constant, since a physical system can not have more than one solution.
