Conservation of angular momentum under central forces
In the discussion on the conservation of angular momentum under central forces, participants confirmed that angular momentum is conserved when the force is central. The equations for radial momentum, ##p=m\dot r = ma\dot \theta=ma\omega##, and angular momentum, ##L=mr^2\dot\theta = ma^2\omega^3 t^2##, were analyzed. It was established that while linear momentum remains constant, angular momentum can be time-dependent due to the influence of tangential velocity. The total linear momentum was expressed as ##p_{\text{tot}}=m(\dot r+r\dot\theta )=m(a\omega + a\omega^2 t)##, emphasizing the need to consider both radial and tangential components.
  • Understanding of central forces in physics
  • Familiarity with angular momentum and its mathematical representation
  • Knowledge of linear momentum and its conservation laws
  • Basic calculus, including the chain rule
  • Study the derivation of angular momentum equations in central force motion
  • Learn about the relationship between tangential and radial velocities in circular motion
  • Explore the implications of non-central forces on momentum conservation
  • Investigate the use of vector addition for momentum components
Students of physics, particularly those focusing on mechanics, educators teaching angular momentum concepts, and researchers examining the effects of central forces on motion.
Saptarshi Sarkar
If a particle moves outward in a plane along a curved trajectory described by ##r=a\theta##, where ##\theta=\omega t##, where ##a## and ##\omega## are constants, then its
a) kinetic energy is conserved
b) angular momentum is conserved
c) total momentum is conserved
d) radial momentum is conserved
##p=m\dot r##
##L=mr^2\dot \theta##
I know that the force must be a central force and that under central forces, angular momentum is conserved. But I am unable to mathematically show if the angular and linear momentum are constants.
Radial Momentum
Angular Momentum
I am not sure if I am supposed to use the chain rule here, but I am getting a conserved linear momentum but a time-dependent angular momentum.
Angular Momentum
Isn't that the answer for ##L##?
For the other part, are you looking for radial momentum or total linear momentum?
I was thinking that the angular momentum must be independent of time as it looks like a trajectory under a central force. Is it not true?
For the other part, I did a mistake. Thanks for pointing it out. I need to consider the tangential velocity as well.
Total linear momentum = ##p_{\text{tot}}=m(\dot r+r\dot\theta )=m(a\omega + a\omega^2 t)##
So, d should be the answer?
Yes. It's not a central force. You can calculate the acceleration if you want to. It won't be in the radial direction.
The two components are perpendicular to each other. You can't just add them together as scalars.
  • · Replies 17 ·
  • · Replies 71 ·
16K
