Conservation of Energy and a spring
A 2.4 kg block dropped from a height of 5 m compresses a spring with a force constant of 3.96 x 103 N/m by 25 cm. When the spring is compressed by 15 cm, the block retains kinetic energy, which can be calculated using the conservation of energy principles. The relevant equations include gravitational potential energy and elastic potential energy, leading to the conclusion that the speed of the block at 15 cm compression can be derived from the difference in energy states.
  • Understanding of gravitational potential energy (Ep = mgy)
  • Knowledge of elastic potential energy (Ep = 1/2 ky2)
  • Familiarity with kinetic energy equations (Ek = 1/2 mv2)
  • Basic principles of conservation of energy
  • Calculate the speed of the block at different spring compression levels using energy conservation.
  • Explore the effects of varying mass and spring constants on energy transfer.
  • Investigate real-world applications of spring mechanics in engineering.
  • Learn about energy loss due to non-conservative forces in similar systems.
Physics students, mechanical engineers, and anyone interested in understanding energy conservation in mechanical systems.
maniacp08
A 2.4kg block is dropped onto a spring with a force constant of 3.96*10^3 N/m from a height of 5m. When the block is momentarily at rest, the spring is compressed by 25cm. Find the speed of the block when the compression of the spring is 15cm.
Relevant equations:
External Work = change in mechanical energy = change in potential energy of spring + change in potential energy of gravity + change in kinetic energy
External Work = 0
for change in potential energy of the spring I did
final - initial
1/2 K (.15m)^2 - 1/2 K (.25m)^2 = -79.2J
for change in potential energy of gravity I did
final - initial
?? - mgh
for change in KE I did
final - initial
1/2 m v^2 - 0
Im not sure what the final potential energy of gravity is... should it be 0 since it is converted to potential energy of the spring?
Would it be
0 = -79.92 - mgh + 1/2 m v^2
and solve for v?
Hello maniacp08,
What I would do is look at what happens to the total energy of the system *in sequence*. Initially, because the object has some height, it has gravitational potential energy. Let's use the coordinate y for vertical position. Let's say y = 0 occurs at the spring. Then the object's initial height is y0 = 5, and its gravitational potential energy is
E_p = mgy_0
Then, as it falls, all of that gravitational potential energy is converted into kinetic energy, so that at the moment that it hits the spring, it has kinetic energy:
E_k = \frac{1}{2}mv^2 = mgy_0
It compresses the spring until all of its kinetic energy has been converted into elastic potential energy, at which point its velocity is zero and therefore it has stopped (let's call this point y1 = -25 cm:
E_p = \frac{1}{2}ky_1^2 = mgy_0
As you can see, the net result of this is to turn the gravitational potential energy the object initally had before being dropped into elastic potential energy. Now, at some earlier spring compression (let's call it y2 = -15 cm), NOT ALL of the object's kinetic energy has been converted into elastic potential energy yet. It still has some kinetic energy, which means it still has some velocity v', and we want to figure out what that is. The difference between its *initial energy* (which is the total energy of the system), and the elastic energy stored in the spring at y2 gives us the leftover kinetic energy:
mgy_0 - \frac{1}{2}ky_2^2 = E_k = \frac{1}{2}mv^{\prime}^2
Edit: I just realized that I forgot to add in the (negative) gravitational potential energy that the object would have at height y2. It's necessary to do that in order for things to work out properly.
Wow, thanks for the very detailed explanation.
I understand it now. Thanks again cepheid.
  • · Replies 20 ·
  • · Replies 58 ·
