Stephen Tashi said:
Yes, there are mechanisms by which energy is supplied to a source radiating energy. But my question is why (from the viewpoint of classical physics) must a radiation source need energy to power it?
Good question. There are more ways to answer. I will answer based on a theory where there are only two kinds of energy: energy of material particles (##\gamma m c^2##) and energy of EM fields (exact expression does not matter for this post). No chemical or other macroscopic concepts of energy are assumed.
Say we have a shining bulb connected to battery and this whole system is enclosed in a sphere.
If the light of the bulb is observed, it is natural to assume positive energy leaves the region. This cannot be proven theoretically without immensely difficult simulation of motion of charged particles in the circuit. It is reasonable so we assume it.
If there is nobody to observe the radiation, not even a charged particle to experience the EM force, in principle we cannot know what happens (it is a hypothetical scenario) but we assume that the process is more or less the same. In other words, even if there is nobody to experience the radiation far from the bulb, it is assumed it is still there more-less as in the case above.
Now that we
assume positive amount of EM energy leaves the region through the sphere during every unit of time, this amount has to be equal to magnitude of decrease of total energy inside the region. This follows from the work-energy theorem. The theorem itself follows from the basic laws of mechanics and electromagnetic theory and is quite similar in logic to what happens in ordinary mechanics.
The energy decrease inside the sphere may be divided into two components. First, material particles in the system may decrease their kinetic energies. Second, the EM energy inside the system may decrease.
In our case, it is reasonable to assume the kinetic energy of matter particles in the bulb and battery actually slightly increases due to heating. The whole decrease of energy thus has to be due to decrease of EM energy inside the sphere. Obviously, this happens in the battery.
If the radiation is only the "potential to do work", we don't know the radiated field is ever called upon to do actual work.
The radiated EM field far from source may not do any work ever there, but that is not really important, because EM forces generally do some work
inside the source. The ##W## in the work-energy theorem is work done on the particles in the region, not far from it.
If positive energy is lost from the region, the internal EM forces always do work on the charged particles in it and tend to decrease their kinetic energy. They have damping effect on their motion.
This happens, for example, to an isolated piece of glowing cinder, filament of disconnected bulb, antenna cut from the energy feed - as time goes, the radiation gets weaker as the kinetic energy and EM energy of the particles inside the source decreases.
If this does not happen, like in the case of steadily shining bulb or radiating antenna which radiate the same way for long time, there is another process (EM forces) that supplies the necessary energy and counteracts the above damping effect.
To eliminate considerations of internal resistance, friction, etc, we could imagine two charged masses connected by an ideal spring and set in oscillation in a frictionless environment. Such a system should create an time varying EM field and (I think) should radiate energy. Is that correct?
Yes in the common scenario where the fields of the particles are assumed to be retarded solutions of the inhomogeneous wave equation. The radiation will be strongest when the charges have opposite signs. If they are the same, electric moment won't change during the oscillation and the radiation will be weak.
Must I imagine that there are other charged masses outside the system that are moved and acquire kinetic energy?
No. The situation is simplest to analyse when there are no other charged particles at all. Adding further particles will complicate the system of equations. If they are far away, their effect is negligible so it is OK to simplify.
As the charge pair radiates energy away, its motion is damped down to rest. How? The two charges produce two different fields and act on each other. Because changes in EM field propagate with finite speed, the EM forces will not be in phase with the elastic force of the spring and will damp the motion. An approximate differential equation of motion for mutual distance can be set up for the system. EM force on particle 1 due to particle 2 is a function of past position, velocity and acceleration of the particle 2 (in the expression of its retarded field), and vice versa. Due to the delay in the retarded fields, the forces are not in phase with the elastic spring force and cause damping of the oscillating motion.
