Conservation of Energy Question
The discussion revolves around a conservation of energy problem in structural mechanics, specifically using the equation 1/2 * Load * Displacement = Sum of (P^2 * L/2AE). The user provided specific values: A = 1x10^3 m^2, FAB = 90kN, FBC = 120kN, Length of AB = 1.5 m, and Length of BC = 2 m. The user's calculated displacement was 1.33 mm, while the correct answer is 2.08 mm, indicating an error in their calculations or assumptions. The discrepancy suggests a need for a review of the application of the formula and the values used in the calculations.
  • Understanding of structural mechanics principles
  • Familiarity with the conservation of energy in mechanical systems
  • Knowledge of stress and strain calculations
  • Proficiency in using equations related to axial loading
  • Review the derivation and application of the conservation of energy equation in structural mechanics
  • Study the effects of axial loads on displacement in beams and trusses
  • Learn about the significance of material properties such as Young's modulus in calculations
  • Practice similar problems involving energy methods in structural analysis
This discussion is beneficial for engineering students, structural analysts, and professionals involved in mechanical design and analysis who are looking to deepen their understanding of energy conservation principles in structural mechanics.
smr101
Having problems with part (c) here, question is attached below in full.
Using the equation 1/2 * Load * Displacement = Sum of (P^2 * L/2AE)
From the past questions I have the following info, these are also included in the solutions so are accurate:
A = 1x10^3 m^2
FAB = 90kN
FBC = 120kN
Length of BC = 2 m
My attempt at the solution:
1/2 * 150 x 10^3 * Displacement = 1/(2 * 1x10^-3 * 205x10^9) * ((90x10^3^2 * 1.5)+ (120x10^3^2 * 2))
Displacement = ((90x10^3^2 * 1.5)+ (120x10^3^2 * 2)) / 1x10^-3 * 205x10^9 * 150x10^3
= 1.33 mm
The correct answer, per the solutions, is 2.08 mm.
Any idea where I've gone wrong?
Thanks.
Any ideas?
