Conservation of energy - velocity problem
16 replies · 5K views · last reply
lolzwhut?
A bead slides without friction around a loop-
the-loop. The bead is released from a height
of 26.7 m from the bottom of the loop-the-
loop which has a radius 9 m.
The acceleration of gravity is 9.8 m/s2 .
Diagram:
http://img31.imageshack.us/img31/2377/19550530.png
What is its speed at point A?
Answer in units of m/s.
a of grav = 9.8 m/^2
released from: 26.7 m
loop radius 9 m
PE = mgh
Ke = .5mv^2
Ok so this is what I did. I set the PE and KE equations equal to each other so mass can cancel out because its not given.
MGH = .5mv2 >>>> which turns out to be >>> V=sqrt(2*g*h)
To get height i did 26.7-9= 17.7
Then I plugged it into the equation:
v = sqrt(2 * 9.81 * 17.7)
= 18.64 m/s
I submitted the answer and it was wrong still!
omg, someone please explain what am i doing wrong! physics test soon :(
What is the total energy of the system?
At point A, what types of energy does the bead have?
Wouldn't KE be 0? I'm not sure how to do this one..I'm really confused
nope. KE is not zero, so what is an expression for the energy at point A?
mgh=1/2mv^2?
Velocity is 0 at that point becuse its the maximum
lolzwhut? said:
mgh=1/2mv^2?
No. The velocity is not zero. At point A, there is are two types of energy present. The initial energy is converted into these two types.
Potential Energy and Kinetic Energy yes?Thats why I set them equal to to cancel out mass. But its still incorrect.
i think if the object is ROTATING ( because i haven't understood if it is sliding means rotating or not) then
PE= linear KE+ Rotational KE.
maybe this can help us!
i am not sure anyway..we had just learned about it.
Good, at A there is mgh+ 1/2 mv2 put this equal to the initial energy now.
wouldn't that be correct?
you'd have
mgH=mgh+1/2mv2
rock.freak667 said:
you'd have
mgH=mgh+1/2mv2
But we'd still have 1 mass left in the equation. Or do all 3 of them cancel out x_x
one bead...all the same mass :smile:
I don't understand what you mean lol. It doesn't give us a mass. So why use mass in the equation when not even all of them cancel out. How am I supposed to solve it with that equation. I'm confused xD
Diagram:
loop radius 9 m
PE = mgh
Ke = .5mv^2
= 18.64 m/s
This discussion is getting too cluttered when you're already on the right path. The only mistake you made here is that you got the height wrong. It should be 26.7 - 18 = 8.7 meters. Remember, you want the height difference between your original point and your final point (so if radius is 9, the diameter of the hoop is 18). You should get 13.1 m/s.
That's the easy way to do it. The harder way would be to calculate the velocity of the particle at the bottom with the equation v = sqrt(2 * 9.8 * 26.7). Then plug that into the kinematics equation: v(final)^2 = v(initial)^2 + 2ax, where v(initial) is what you calculated in the previous equation. Solve for v(final) and that would also give you the same answer.
:o, thanks a ton man. I think this was a trick question...Since I never thought of the diameter. It makes sense why its 26.7-18 instead of 9.
Thanks for clearing it up, I was really starting to get a little confused there.
