Conservative Forces - Maths of Force & Energy
The discussion focuses on the analysis of conservative forces acting on a particle moving along the parabola defined by the equation y = x². The radial force, represented as Fₐ = -A r³ ẑ, is confirmed to be conservative, as its curl equals zero. In contrast, the force Fᵦ = B(y²î - x²ĵ) is non-conservative, yielding a non-conservative work of Wⁿᶜ = (3B/10) when evaluated along the path from (1,1) to (0,0). The final speed of the particle at the origin is derived using energy conservation principles, resulting in the equation v_f² = v₀² + (A/2m) + (3B/5m).
  • Understanding of vector calculus, specifically curl and gradient operations.
  • Familiarity with conservative and non-conservative forces in physics.
  • Knowledge of energy conservation principles in mechanics.
  • Ability to perform line integrals in a coordinate system.
  • Study the properties of conservative forces and their implications in physics.
  • Learn about line integrals and their applications in calculating work done by forces.
  • Explore the mathematical derivation of potential energy functions for various force fields.
  • Investigate the application of curl in different coordinate systems, including polar and cylindrical coordinates.
Students of physics, particularly those studying mechanics, as well as educators and anyone interested in the mathematical foundations of force and energy concepts.
geoffrey159
A particle of mass m moves in a horizontal plane along the parabola ##y = x^2##. At t=0, it is at the point (1,1) with speed v0. Aside from the force of constraint holding it to the path, it is acted upon by the following external forces:
A radial force: ##\vec F_a = -A r^3\hat r##
A force given by : ##\vec F_b = B (y^2\hat \imath - x^2 \hat \jmath)##
where A,B are constants.
a- Are the forces conservative?
b- What is the speed ##v_f## of the particle when it arrives at the origin ?
curl, integration on a path
Hello, I've just started a new chapter about mathematical aspects of force and energy. It's a little hard to digest at the beginning so maybe you can check my work. Thanks !
a - To test whether a force is conservative, I must check that ##\vec \nabla \times \vec F = \vec 0 ##, but I'm going to need an expression of the gradient in polar coordinates for the (x,y) plane. I believe that it is ##\vec \nabla = \frac{\partial .}{\partial r} \hat r + \frac{1}{r} \frac{\partial .}{\partial \theta} \hat\theta + \frac{\partial .}{\partial z} \hat k## because if ##g = g(r,\theta,z)##, then its differential is
## \begin{array}{ccr}
dg := (\nabla_{\hat r} g)\ dr + (\nabla_{\hat \theta} g)\ ds + (\nabla_{\hat k} g)\ dz
& \text{and} &
\begin{align}
dg =& \frac{\partial g}{\partial r}\ dr + \frac{\partial g}{\partial \theta} \ d\theta
+ \frac{\partial g}{\partial z}\ dz \\
=& \frac{\partial g}{\partial r}\ dr + \frac{\partial g}{\partial \theta} \ (\frac{ds}{r}) + \frac{\partial g}{\partial z}\ dz
\end{align}
\end{array} ##
So if you confirm this is right,
\begin{array}{cc}
\vec \nabla \times \vec F_a =
\begin{vmatrix}
\hat r & \hat \theta & \hat k \\
\frac{\partial .}{\partial r} & \frac{1}{r} \frac{\partial .}{\partial \theta}& \frac{\partial .}{\partial z} \\
-A r^3 & 0 & 0
\end{vmatrix} = \vec 0
\vec \nabla \times \vec F_b =
\begin{vmatrix}
\hat \imath & \hat \jmath & \hat k \\
\frac{\partial .}{\partial x} & \frac{\partial .}{\partial y}& \frac{\partial .}{\partial z} \\
B y^2 & -Bx^2 & 0
\end{vmatrix} = -2B(x+y) \hat k\neq \vec 0
\end{array}
So that only the radial force is conservative.b- ##\vec F_b## does a non-conservative work on the path ##y = x^2## from x=1 to x=0, so its work is :
## \begin{align}
W^{(nc)} =& B \int_{(1,1)}^{(0,0)}(y^2 dx - x^2 \ dy) \\
=& - B\int_{0}^{1} (x^4\ dx - x^2 (2x\ dx)) \\
=& \frac{3B}{10}
\end{align}##
The potential fonction of the radial force is ##U_a(\vec r) = \frac{A}{4} r^4##.
By conservation of total energy,
##E_f - E_i =W^{(nc)} \Rightarrow v_f^2 = v_0^2 + \frac{A}{2m} +\frac{3B}{5m}##
up
Your result is correct, but check the formula for curl in cylindrical coordinates.
Thanks ! I've just checked on the internet, it's the same thing with 1/r factored out of the determinant
