Conservative Forces - Maths of Force & Energy
The discussion focuses on determining the conservative nature of two forces acting on a particle moving along a parabolic path. The radial force is confirmed to be conservative, while the second force is non-conservative due to its non-zero curl. The work done by the non-conservative force is calculated, leading to an expression for the final speed of the particle as it reaches the origin. The total energy conservation principle is applied to relate initial and final speeds, incorporating the work done by the non-conservative force. The conversation emphasizes the importance of correctly applying mathematical concepts in physics problems.
geoffrey159
A particle of mass m moves in a horizontal plane along the parabola ##y = x^2##. At t=0, it is at the point (1,1) with speed v0. Aside from the force of constraint holding it to the path, it is acted upon by the following external forces:
A radial force: ##\vec F_a = -A r^3\hat r##
A force given by : ##\vec F_b = B (y^2\hat \imath - x^2 \hat \jmath)##
where A,B are constants.
a- Are the forces conservative?
b- What is the speed ##v_f## of the particle when it arrives at the origin ?
curl, integration on a path
Hello, I've just started a new chapter about mathematical aspects of force and energy. It's a little hard to digest at the beginning so maybe you can check my work. Thanks !
a - To test whether a force is conservative, I must check that ##\vec \nabla \times \vec F = \vec 0 ##, but I'm going to need an expression of the gradient in polar coordinates for the (x,y) plane. I believe that it is ##\vec \nabla = \frac{\partial .}{\partial r} \hat r + \frac{1}{r} \frac{\partial .}{\partial \theta} \hat\theta + \frac{\partial .}{\partial z} \hat k## because if ##g = g(r,\theta,z)##, then its differential is
## \begin{array}{ccr}
dg := (\nabla_{\hat r} g)\ dr + (\nabla_{\hat \theta} g)\ ds + (\nabla_{\hat k} g)\ dz
& \text{and} &
\begin{align}
dg =& \frac{\partial g}{\partial r}\ dr + \frac{\partial g}{\partial \theta} \ d\theta
+ \frac{\partial g}{\partial z}\ dz \\
=& \frac{\partial g}{\partial r}\ dr + \frac{\partial g}{\partial \theta} \ (\frac{ds}{r}) + \frac{\partial g}{\partial z}\ dz
\end{align}
\end{array} ##
So if you confirm this is right,
\begin{array}{cc}
\vec \nabla \times \vec F_a =
\begin{vmatrix}
\hat r & \hat \theta & \hat k \\
\frac{\partial .}{\partial r} & \frac{1}{r} \frac{\partial .}{\partial \theta}& \frac{\partial .}{\partial z} \\
-A r^3 & 0 & 0
\end{vmatrix} = \vec 0
\vec \nabla \times \vec F_b =
\begin{vmatrix}
\hat \imath & \hat \jmath & \hat k \\
\frac{\partial .}{\partial x} & \frac{\partial .}{\partial y}& \frac{\partial .}{\partial z} \\
B y^2 & -Bx^2 & 0
\end{vmatrix} = -2B(x+y) \hat k\neq \vec 0
\end{array}
So that only the radial force is conservative.b- ##\vec F_b## does a non-conservative work on the path ##y = x^2## from x=1 to x=0, so its work is :
## \begin{align}
W^{(nc)} =& B \int_{(1,1)}^{(0,0)}(y^2 dx - x^2 \ dy) \\
=& - B\int_{0}^{1} (x^4\ dx - x^2 (2x\ dx)) \\
=& \frac{3B}{10}
\end{align}##
The potential fonction of the radial force is ##U_a(\vec r) = \frac{A}{4} r^4##.
By conservation of total energy,
##E_f - E_i =W^{(nc)} \Rightarrow v_f^2 = v_0^2 + \frac{A}{2m} +\frac{3B}{5m}##
up
Your result is correct, but check the formula for curl in cylindrical coordinates.
Thanks ! I've just checked on the internet, it's the same thing with 1/r factored out of the determinant
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
