Consistent Histories and Locality
105 replies · 12K views
Morbert said:
we can identify a maximally refined sample space for which all other sample spaces are coarse grainings.
Yes, that's the "principle of uniticity" that QM violates.
Morbert said:
We cannot do this for a quantum system
Yes.
Morbert said:
the different samples spaces describing a quantum system are still describing that system.
None of them are describing all of the measurements that can be made on that system. None of them even describe all the measurements that are made on that system, in a case like entanglement swapping. If one of them did, QM would not violate the "principle of uniticity".
Yes.
Any sequence of measurements that are actually carried out will be describable by a single framework (albeit not a unique one). This is because the pointer states recording the measurement results will guarantee decoherence.
That's not what Griffiths appears to be saying. If it were true, the principle of uniticity would not be violated by QM. But Griffiths says it is.
Well, for the existing entanglement swapping experiments, each measurement is done on a different pair of photons. You would probably model those measurements by a tensor product, because the different pairs are effectively distinguishable. But for repeated measurements on the same particle(s), your explanation is fine.
That your answer doesn‘t address PeterDonis‘ and my objections is a different topic.
In case there are crossed wires:
i) No single framework can describe all measurable properties of a quantum system. This is a violation of the principle of unicity.
ii) No lab protocol can measure all measurable properties of a quantum system.
iii) Even though no single framework can describe all measurable properties of a system, any protocol that is actually executed can be described by a single framework.
A simple example:
i) The spin-x and spin-y properties of a particle cannot be described by a single framework.
ii) No lab protocol can measure both the spin-x and spin-y properties of a particle at the same time.
iii) The protocol to measure the spin-x property of a particle can be described by a single framework. The protocol to measure the spin-y property of a particle can be described a single (different) framework.
My explanation is fine for entanglement swapping experiments too. Histories as chains of projectors is readily applicable to entanglement swapping experiments.
My answer did.
Morbert said:
1. Yes, and so below I've constructed histories for the actual ##\Phi^+, \Phi^-, \mathrm{fail}## scenarios. Hopefully it will not be too confusing and we can revisit the quantum state of the experiment if need be.
2. I am including degrees of freedom of the labs so that the experiment can be approximated by a pure state and unitary time evolution. This simplification is common but in the end it will only be relevant if you object to my claim that the histories I construct below are in fact decoherent.
The quantum state is not interpreted as real, and instead only yields probabilities for real alternatives. So yes in reality at II the polarization would be known to the experimenter.
3. Let's now construct a set of histories relevant to describing this experiment. For expediency I will only describe histories for which the probability is > 0. We can place the projector ##\left[\psi^-_{12}\right]## at time ##I## as the first element of our histories. To describe the measurement at ##II##, we will add a branch just before, giving us$$\left[\psi^-_{12}\right]\odot\begin{cases}\left[h_\omega\right]_1&\odot&\left[1\right]_{A}\\\left[v_\omega\right]_1&\odot&\left[0\right]_{A}&\end{cases}$$Along the upper branch, the measurement result 1 reveals a horizontal polarization (relative to the chosen aspect), along the lower branch, the measurement result 0 reveals a vertical polarization. We will follow the upper branch, with the understanding that the lower branch has a similar structure. The next relevant event is at ##III##, the creation of the 34 pair
$$\left[\psi^-_{12}\right]\odot\left[h_\omega\right]_1\odot\left[1\right]_{A}\odot\left[\psi^-\right]_{34}$$Before the BSM at ##IV## we can describe the polarization of photon 4 with the branch$$\left[\psi^-_{12}\right]\odot\left[h_\omega\right]_1\odot\left[1\right]_{A}\odot\left[\psi^-\right]_{34}\odot\begin{cases}
\left[h_\omega\right]_4\\
\left[v_\omega\right]_4
\end{cases}$$Then, at ##IV##, we have the BSM. The ##v_\omega## polarization of 4 will be correlated with a failed BSM, so we have a branching of the form
\left[h_\omega\right]_4&\odot&\begin{cases}\left[
\Phi^+\lor\Phi^-\right]_\mathrm{BSM}\\
\left[\mathrm{fail}\right]_\mathrm{BSM}\end{cases}\\
\left[v_\omega\right]_4&\odot&\left[\mathrm{fail}\right]_\mathrm{BSM}
\end{cases}$$Following the upper branch again and extending it to the measurement of 4, we have a completed history$$\left[\psi^-_{12}\right]\odot\left[h_\omega\right]_1\odot\left[1\right]_{A}\odot
\left[\psi^-\right]_{34}\odot\left[h_\omega\right]_4\odot\left[\Phi^+\lor\Phi^-\right]_\mathrm{BSM}\odot\left[1\right]_B
$$Each of these histories ##C## has the probability of occurring ##p(C) = \mathrm{tr}C^\dagger\left[\Psi_0\right] C## and we can user them to compute the relevant conditional probabilities that correlate a successful BSM with certain correlation between the polarizations of 1 and 4.
4. Unlike a scenario where the BSM instantly influences photon 4, and retroactively influences photon 1 to entangle them, these histories describe a scenario where a successful BSM reveals a correlation between the polarization of 1 and 4.
1. The experiment only considers the Φ- cases.
2. We start with just one entangled pair, and you adding the extraneous stuff serves no purpose I can see. So I ask again: After photon 1 is measured, do we know the polarization of photon 2 or not? Because according to the usual local concepts, its polarization on the L/R basis should be known/certain and its polarization on the V/H basis should be completely unknown/uncertain. Well according to CH, is it?
You seem to agree with the L/R portion of my statement. But you model the R/L portion as being a superposition of H and V (your upper/lower paths) in the 3. section. But now you run afoul of the CH concept of frameworks: you have both the L/R and V/H frameworks modeled together. You previously pointed out (as Griffiths does): "The spin-x and spin-y properties of a particle cannot be described by a single framework." And "No lab protocol can measure both the spin-x and spin-y properties of a particle at the same time." And yet, here you are describing both the L/R and H/V properties of a photon at the same time.
I would state that there is no correlation whatsoever between the L/R and H/V and properties of any photon, since they are mutually unbiased. Similarly, I would state that there is no correlation whatsoever between the L/R or H/V properties of a photon in a superposition, with the L/R or H/V properties of a different photon in a superposition - UNLESS these photons are entangled. Coming from different sources, they can't start out that way. How can you object to any element of this paragraph? This is basic.
3. My objections are not addressed, and there are no answers to the points I made in my previous commets/posts. Specifically, once I know the photon 1 is (say) |L>, which tells us the polarization of photon 2 by inference; and then it is measured on the "inconsistent" basis V/H: How does any of this bring about or otherwise lead us to the correlation of photon 4 on yet another "inconsistent" basis L/R (since photon 3 was measured on the V/H basis).
4. There is no correlation whatsoever between the 1 and 4 photons UNLESS a swap occurs. You completely and totally skip over the critical point of this scientific experiment, which is: For the swap to occur, there must be physical overlap at the BSM. That is controllable by the experimenter. According to your logic, that shouldn't matter. The results say that the choice of the experimenter creates a correlation that does not otherwise exist.
And as I am fond of adding: The speculative concept of a "hidden" relationship between photons 1 & 4 is completely contrary to the concept of Monogamy of Entanglement. Where is this addressed by CH? Or is MoE wrong? I would point out that MoE theory is newer than CH.
And as I also keep pointing out: The authors of these papers say precisely the opposite of your claim of there being a correlation waiting to be "revealed" (because the relationship is created by the BSM, not revealed):
Kaltenbach et al: "We confirm successful entanglement swapping by testing the entanglement of the previously uncorrelated photons 1 and 4."
Ma et al: "This [BSM] effectively projects the two already registered photons onto one definite of two mutually exclusive quantum states in which either the photons are entangled (quantum correlations) or separable (classical correlations)."
Megadish et al: "This [experiment] is a manifestation of the non-locality of quantum
mechanics not only in space, but also in time.
2. If the result of the linear polarization measurement of photon 1 is H, then this reveals the linear polarization of photon 2 is V, and vice versa, as the 1,2 photons were prepared in the ##\psi^-## state.
An important point about the CH notation: Different branches represent mutually exclusive alternatives, not superpositions. Histories here are represented by chains of projectors. More specifically, the square brackets are time-evolved projectors (e.g. ##\left[H\right]## = ##U(t,t')|H\rangle\langle H | U(t',t)## and ##\odot## is just ##\otimes##. Griffiths uses ##\odot## to demarcate projectors at different times. As such, the histories I wrote above only reference the linear polarization of photons 1 and 4, and make no reference to the circular polarization of any photon. If we instead measure the circular polarization of 4, we can build the branching$$\left[\psi^-_{12}\right]\odot\left[h_\omega\right]_1\odot\left[1\right]_{A}\odot\left[\psi^-\right]_{34}\odot\begin{cases}
\left[R\right]_4\\
\left[L\right]_4\end{cases}$$The mutually unbiased nature of these bases means a measurement of the linear polarization of 1 will tell us nothing about the circular polarization of 4, whether or not a BSM is carried out.
3. I'm not sure I understand this. If a BSM is carried out, then photon 2 is not measured in any basis. Instead the 2,3 photons are measured in a Bell basis. If photons 2,3 are measured in some separable state basis like {HH, VV} described by Ma, then the measurement result of 1 reveals nothing about 4.
4. I was following the Megedish convention of a successful BSM or a failed BSM (due to temporal distinguishability). We could just as readily, say, model a BSM or separable state measurement of 2,3 with a quantum random number generator like Ma does.
Ultimately, what CH allows us to say is i) for any given run, a measurement of photon 1 and a successful BSM will reveal the associated property of photon 4. ii) For all runs, there will be a correlation between a successful BSM of 2,3 and Bell-inequality-violating correlations between measurements on 1 and 4.
As CH is an interpretation of standard QM (and QFT) without any extension of the theory, it doesn't and can't contradict any feature of the theory. CH is 100% consistent with MoE. [edit] For example, CH never permits us to make a statement like: "Photon 1 is maximally entangled with photon 2, and photon 1 is also maximally entangled with photon 4"
I think the quotes by Ma et al would bring us back into a general discussion of nonlocality. For the time being I'll try to focus on CH as it applies to entanglement swapping experiments or other experiments involving Bell-inequality-violating correlations.
I know that this is the point of disagreement and we have discussed it many times. But this, as stated, is not correct.
The pair 1&4 has a density matrix, which does not change no matter what is done or not done on the reset of the system, the pair 2&3. This density matrix gives the probability of the possible outcomes on any possible measurement done on 1&4. Which means that in each series of trials there will be a subset of the full set of results that have outcomes of the corresponding Bell state of 1&4. If Victor has been measuring 2&3 in the Bell state basis the subset will be precisely those trials on which Victor got ##|\Phi^-\rangle## (I might be using the wrong notation) as a result. If Victor has being doing measurements in a different basis or no measurements at all, the full set will not show the same correlations, but there will be a subset with those correlations.
The fact that the probabilities for outcomes of measurements on 1&4 are independent of what is done on 2&3 shows that there is no action at a distance. At least to me this is the only possible conclusion. Clearly many people think otherwise. Why? I still don't know! Of course it is a possibility but I don't see any indication for it from the theory nor the experiments. They only confirm the theory.
CH proponents in general don't like to frame QM as concerning the statistics of ensembles. E.g.
Understanding Quantum Mechanics
Roland Omnes said:
Some people believe, on the contrary, that the probabilistic character of quantum physics is best expressed if one considers conceptually infinite ensembles of identical systems, as in statistical mechanics. This approach, however, must be excluded when one intends to include classical physics within the quantum framework. In that case, considering an infinite collection of copies of the solar system would certainly then be odd
Probabilities and Quantum Reality: Are There Correlata?
Mermin said:
The theory should describe individual systems — not just ensembles
The theory should describe individual systems because the world contains individual systems. . . and the theory ought to describe the world and its subsystems. . . In a nondeterministic world probability has nothing to do with incomplete knowledge, and ought not to require an ensemble of systems for its interpretation. . . The fact that physics cannot make deterministic predictions about individual systems does not excuse us from pursuing the goal of being able to describe them as they currently are.
Griffiths said:
On these five desiderata I agree two hundred percent with Mermin. In some cases I may be giving his words a slightly different interpretation from what he intended, but at least in broad outline and probably in most of the details, I could not agree with him more, even though I could not possibly have expressed it with such clarity and enthusiasm.
If statistical statements are insisted on, then we would say a history ##C## represents a subensemble of experimental runs where measurement results asserted by that history occur. The relative frequency of all events asserted by the history occurring is ##\mathrm{tr}C^\dagger\rho C##.
Over the full ensemble, i.e. over all histories, there will be no Bell-inequality-violating correlations between 1 and 4 measurement outcomes.
Over all histories where a BSM with possible results ##\{\left[\phi^+\right]_{23},\left[\phi^-\right]_{23}, I - \left[\phi^+ \lor \phi^-\right]_{23}\}## occurs, there will be no Bell-inequality-violating correlations between 1 and 4 measurement outcomes.
Over all histories where a BSM with the result ##\left[\phi^-\right]_{23}## occurs, there will be Bell-inequality-violating correlations between 1 and 4 measurement outcomes
One has to be very careful phrasing this. As you state it, it could be true or it could be false, depending on how your ambiguous wording is interpreted.
It is impossible to send signals to observers measuring photons 1 & 4 by choosing whether or not to allow a swap operation to take place on photons 2 & 3 at the BSM. In that sense your statement is true.
However, if you do two experiments, one in which the swap operation is done and one in which it is not, and you hand the two sets of data (the measurement results by run for all four photons) to someone, without telling them which set is the "swap" set and which is the "no swap" set, they can tell which is which by looking at the photon 1 & 4 correlations in each subset picked out by the four possible combinations of photon 2 & 3 results. In the "swap" set, there will photon 1 & 4 correlations in each subset, and those correlations can violate the Bell inequalities, whereas in the "no swap" set there will be no correlations even by subset. In that sense your statement is false.
My point is that if you give them the two sets of the measurement result only of photons 1&4, then they cannot tell which is which.
Yes, but why would you do that? Photons 2 & 3 are part of the total system; photon 2 starts out entangled with photon 1, and photon 3 starts out entangled with photon 4, and those entanglements are stipulated in the preparation of the system. If you leave out those results, you're leaving out relevant information.
It is of course true that a reduced density matrix for a quantum system that traces over other systems with which that system might be entangled, will not show correlations with those other systems. That's a simple mathematical fact that is stated in pretty much every QM textbook. But that doesn't mean those correlations do not exist, or that they are not physically meaningful.
But the claim is that measurment on 2&3 affects 1&4. What is the meaning of that if it cannot be observed?
It can be observed: when you look at the presence or absence of correlations in the 1&4 subsets corresponding to the four possible combinations of 2&3 results, depending on whether the experimenter made a choice to have a swap take place, you are observing that the experimenter's choice of whether or not to make a swap at 2&3 affects 1&4. In any other branch of science, that would be a commonplace claim: experimenter makes an intervention and the presence vs. the absence of that intervention shows up in a predictable way in the data. Why it somehow becomes problematic when we're talking about QM and entangled systems is not clear to me.
I don't understand. If you don't make a BMS on 2&3 there is still going to be for subsets of the data for 1&4 with those correlations. We may not be able to tell which trials to look at but they are there. So I still don't understand why in one siruation they were caused by something romote and in the other not? Also in any branch of science if the probabilities of the outcomes do not change base on whether you do something over there or not suggests that the doing or not of something over there is not the cause of the outcoms.
No, there will not. That's the whole point. If no swap is done on 2&3, then the 1&4 subsets corresponding to each of the four possible combinations of 2&3 results (HH, HV, VH, VV) will not show any correlations, because photons 1&4 are not entangled if no swap is done. But if a swap is done on photons 2&3, then those four subsets of 1&4 results will show correlations, corresponding to the entangled Bell state that is indicated by each of the four 2&3 combinations.
These correlations do not allow signaling, since they are only detectable once the results are all collected and the subsets picked out. But they are a measurable difference between the swap and no swap cases.
No, i am not saying that the subsets of 1&4 will correspond to the outcomes HH, HV, VH, and VV of the 2&3. I am saying that the data set of the 1&4 can be partitioned into such four subsets.
This makes no sense. Of course you can pick any subsets out of the total 1&4 data set you like, if you don't care what they mean or don't mean. But the subsets that matter, physically, are the ones that correspond to the four possible combinations of 2&3 outcomes--because those are the ones that are predicted by the standard math of QM to show the Bell state correlations if the experimenter chooses to do a swap, but not if the experimenter doesn't. In other words, those are the relevant subsets for testing the theory against experiment.
Of course it can. I'm saying the same thing. And I'm also saying that if you partition the 1&4 data that way, then you will see Bell state correlations in each subset if and only if the experimenter chose to do a swap.
If you dispute this, you are disputing both the standard math of QM and the experimental facts.
martinbn said:
So I still don't understand why in one situation they were caused by something remote and in the other not? Also in any branch of science if the probabilities of the outcomes do not change base on whether you do something over there or not suggests that the doing or not of something over there is not the cause of the outcoms.
You have everything backwards. The 4 fold outcomes DO change depending on "whether you do something over there or not"! That's what the point of the experiment is!! To summarize (for the Nth time):
- 4 fold coincidences when experimenter selects SWAP=on (indistinguishable HH or VV for 2&3): Correlation high, as predicted by QM.
- 4 fold coincidences when experimenter selects SWAP=off: (distinguishable HH or VV for 2&3): Correlation negligible, as predicted by QM.
We are simply saying that there is a published experiment by a top team, and we are asking for a description of how an QM interpretation can explain THAT experiment without recourse to nonlocality. Because to the naked eye, the results appear* to clearly demonstrate non-signaling nonlocality.
What you are saying is that the 2 fold correlated outcomes don't appear to change because we don't know which bin to place the "subsets" in. So what? That's a different experiment and has nothing to do with entanglement swapping. You can test that with any two sources and get the same results. Imagine you are testing the Earth's gravitational acceleration, 32 ft/sec^2. You let an apple fall 16 feet, but you don't record or report the elapsed time duration. That is essentially what you are describing, half an experiment.
*Of course there are Interpretations that are explicitly nonlocal. Other Interpretations may have features that can explain the apparent nonlocality in some manner that retains locality. Those are the explanations I am requesting.
The standard math of QM says that Bell-inequality-violating correlations between the appropriate measurements on 1 and 4 will themselves be correlated with outcomes of a BSM on 2 and 3. This is all the math of QM commits us to. It does not commit us to nonlocal influence unless we insist on a hidden variable theory that reproduces these correlations QM predicts.
Morbert said:
The standard math of QM says that Bell-inequality-violating correlations between 1 and 4 will themselves be correlated with outcomes of a BSM on 2 and 3. This is all the math of QM commits us to. It does not commit us to nonlocal influence unless we insist on a hidden variable theory that reproduces these correlations QM predicts.
That is most certainly not true. Any of the following are consistent with Bell:
a) Denial of locality via nonlocal hidden variables interpretations. (Bohmian, etc.)
b) Denial of hidden variables via various "local" interpretations (MWI, Time symmetric, etc.)
c) Denial of both local and realism/hidden variables. (I would personally place standard QM in this bucket.)
We should probably be discussing type c) in order to be consistent with all of the experiments I am aware of. The Heisenberg Uncertainty Principle - and experiments supporting it - strongly imply there is no realism or hidden variables. Swapping experiments strongly imply Einsteinian locality and causality fails.
The words "nonlocal influence" do not appear anywhere in my post. I am simply trying to make sure we are all clear about what the standard math of QM and the experimental facts say, because the posts by @martinbn appear to me to indicate that that is not clear to everyone in this thread.
I don't dispute any of this. May be I don't express myself well. What confuses me is that it seems that we say exactly the same thing except that you and @DrChinese add at the end "Therefore this proves that the measurements on 2&3 affect the outcomes for 1&4". I just don't see it.
I am not questioning QM nor the experimental facts (which confirm QM, so in a theoretical discussion they are not really needed). I am questioning the conclusions @DrChinese makes from these experiments. He does use the words "nonlocal influence". And I was responding to his post that I quoted.
"Affect" is a very general term. The experimenter's choice of whether or not to do a swap at 2&3 affects whether or not Bell state correlations appear in the measurements on 1&4. That's the experimental fact. What's wrong with using the word "affect" here?
"Nonlocal influence" is a much more specific term than "affect". "Nonlocal influence" is a matter of interpretation; some QM interpretations claim it, some don't. But "affect", as above, is just the experimental fact; whether or not a swap is done at 2&3 makes a difference in whether or not Bell state correlations show up in the measurements on 1&4. If you agree with that last sentence, then I have no issue.
PetersDonis uses “affect” (as a verb). I use the term "nonlocal influence"; the authors of the paper(s) use the terms "quantum steering into the past" and "manifestation of the non-locality of quantum mechanics". These all describe what it looks like to the naked eye, considering that the experimenter can directly (causally?) influence the nature of the correlations observed - regardless of separation in space or time.
But these incredible experiments leave open some paths for interpretation, which is why we discuss this in the Interpretations subforum. My questions are simple: Does anyone know of an interpretations claiming locality that can explain these experiments? If so, I'd like to see the claim explained for the extent experiments. These experiments are roundly ignored by virtually all writers supporting local interpretations (MWI, QBism, Relational, etc.) - other than to merely claim that their (Bell defying) logic applies. These experiments don't need Bell. They are basically extensions of EPR's "elements of reality" updated for modern understanding.
Fine, I am ok with the terms. But I don't understand the reasoning behind the experimental fact. So let me ask you this. Everyone agrees that the full set of measurements on 1&4 show no special correlations. And that there is a subset of 25% of them show correlations that violate Bell's inequality no matter what is done on the rest of the system. If you perform the experiment and do a BMS on 2&3 in 25% of the cases the result will be a projection to the phi minus state, and this subset of trials will match the subset of Bell inequality violating results of 1&4. So far I understand. But then the conclusion that if you don't do the BMS on 2&3 will change the outcome at 1&4 is unclear to me. Since we haven't done the BMS how do we know which subset of result at 1&4 to look at? If I understand you correctly you say that we measure the 2&3 in a different basis and look at the partition for the full set into the four subsets according to the four possible outcomes. But why? We cannot say that one of them would have been the subset with the phy minus state had we done the BMS on 2&3.
I am not so hung up on the terminology. It just that the "directly (causally) influence" is not obvious to me. Not to mention that as you state it it implies influence in the past.
I don't think that any interpretation claims that it is local in the sense of Bell inequality violations. The violations are a mathematical consequence of the theory, so no interpretation can avoid it. I think that all the claim is that they are local in the sense of lac of influence at a distance.
The authors of the paper show that, given some sample of measurements on 1 and 4 over multiple runs, an experimenter can use a BSM to sort the sample into subsamples that exhibit Bell-inequality-violating correlations. This is different from showing that data in the sample is altered (immediately, retroactively or otherwise) by the BSM.
Then entanglement swapping experiments are a red herring as your objections to these interpretations persist even in simpler experiments.
E.g. An experimenter can use CH to model an entanglement swapping experiment run with a set of possible histories and a probability space, and they can infer statements about photon 4 from measurements on photon 1 and photons 2,3 without nonlocal causal influence. Your objections to this approach (e.g. around the violation of the principle of unicity and the non-uniqueness of maximally fine-grained probability spaces) would be present even if we were considering a standard EPRB experiment.
Putting it another way: Entanglement swapping experiments show the establishment of entanglement between distant photons that do not have the same source, or never even coexisted. But none of these local interpretations rely on same-source particles to explain entanglement. They rely on a rejection of realism or on non-unicity or on spacetime state realism or on superdeterminism etc.
