Constant Acceleration - Kinematics Problem Help
The problem involves a train moving with constant acceleration, passing two points at different velocities (50 km/h and 80 km/h). The objective is to determine the train's velocity when it is halfway between these two points, requiring the use of simultaneous equations.
  • Exploratory, Mathematical reasoning
  • Participants discuss the use of kinematic equations to relate initial and final velocities with acceleration and displacement. One participant attempts to set up simultaneous equations to solve for the halfway velocity.
The discussion includes attempts to derive the halfway velocity using kinematic formulas. One participant reports a calculated value for the halfway velocity, but there is no explicit confirmation of correctness or consensus on the approach taken.
The problem specifies that the solution must utilize two simultaneous equations, which may influence the methods discussed.
dd12
A train at constant acceleration is traveling in a straight line. It passes two points at a velocity of 50km/h and 80km/h respectively. What is the exact velocity of the train when it is halfway between these two points?
Let v be the exact velocity of the train when it is halfway between these two points
(Must be solved using two simultaneous equations)
Thanks! :)
So what have you tried?
Using formula V^2=(V(0))^2+2*a*s
where a is acceleration, s is displacement, v is velocity, V(0) is initial velocity:
80^2=50^2+2as (1)
M^2=50^2+(1/2)*2*as (2)
where M is the velocity at halfway
Solved them simultaneously and got M=5*sqrroot(178)
You got the right answer...
  • · Replies 20 ·
15K
  • · Replies 16 ·
  • · Replies 20 ·
