Constant horizontal pull on a sled
9 replies · 12K views · last reply
wondermoose
A constant horizontal pull acts on a sled on a horizontal frictionless ice pond. The sled starts from rest. When the pull acts over a distance x, the sled acquires a speed v and a kinetic energy K. If the same pull instead acts over twice this distance, <the sled's speed will be sqrt(2)v and its kinetic energy will be 2K>?
K=1/2mv^2
The last part between the < > was actually the correct answer as part of a multiple choice question, but I've tried figuring out the relationship and haven't come up with anything. I already missed the question (I thought speed would be 2v and kinetic energy would be 2K), but I would still like to know how those figures and values are found for the future. Thanks!
hi wondermoose! :smile:
the force is constant, so the acceleration is constant …
so use one of the standard constant acceleration equations to find how v depends on s :wink:
Hmm... I don't follow. Do I still use the kinetic energy equation in some regard? Or am I trying to complicate the problem?
Think of the Work-Energy Theorem.
ehild
(just got up :zzz: …)
You can either use the usual equations to find v, or, since you're given the distance in this question, you can (as ehild :smile: says) use the work done to find the KE directly …
either will do! :biggrin:​
Alright, so W=Fd
F=ma
W=m*a*d
and a=v/t
so W = m*v*d/t
deltaK=W
1/2mv^2=m*v*d/t
Is that along the right line? I'm so freakin' confused.
(have a delta: ∆ and try using the X2 icon just above the Reply box :wink:)
why are you introducing a?
∆KE = W = Fd,
so ∆KE is proportional to F, and proportional to d …
carry on from there :smile:​
∆KE = W = Fd,
But where does velocity fit into those relationships? I know the .5mv2 is going to come into play somewhere along the way, but I don't know where or how. Thanks, tim!
tiny-tim said:
speed is √(KE/2m)
Alright, so if K=Fd, and F is constant and d doubles, therefore K doubles. Then, relating back to
√(KE/2m), then if K is 2K then the speed (v) would still be √(2/2m).
v=√(2/2m)
Closer? Thanks
