What Constant Velocity Is Needed to Catch a Bus Accelerating from Rest?
The discussion revolves around calculating the constant velocity required for a person to catch a bus that starts accelerating from rest at 3 m/s², beginning 20 meters away. Participants explore various equations of motion but struggle with the complexity of the problem, particularly the relationship between time, distance, and velocity. A quadratic equation emerges, but there are noted errors in calculations and misunderstandings about the variables involved. It is suggested that without a specific time or velocity, multiple solutions exist, indicating a curve rather than a single answer. The conversation highlights the need for clarity in the problem's parameters to find a minimum velocity for the person.
DigitalSpark
When you are 20m away from your bus it begins accelerating at 3 m/s/s (from rest). With what constant velocity should you run at to catch the bus?
v-u=at
s=ut+\frac{1}{2}at^{2}
v^{2}=u^{2}+2as
I've done loads of ways... and they are all wrong (spent hours). I just a want hint in the right direction as I'd like to solve this by myself. Can someone take me step by step?
I was unable to come up with an actual answer also. Using the equation
x_2 = x_1 + vt + \frac{1}{2}at^2
for the person:
x_1 = 0
a = 0
so you get: x_2 = v_1t
for the bus:
x_1 = 20
v_1 = 0
a = 3m/s^2
so you get: x_2 =20 + \frac{1}{2}3t^2
So, I ended up with two equations and three unknowns, and can only solve in terms of another variable. I tested different time values to get x_2 then solved for v of the person, and it changes from second to second, which makes sense when you think about it. So without a distance traveled or a time where they meet, I don't think there's an actual value i.e. 5 or 10 or 15m/s for velocity.
so you're saying that there's no solution?! lol
wow... I tried a few ways... and since V(of person) is constant, I just used that as a constant.
Let me show you:
Speed=Distance/Time
Distance of Man= 20(metres)+1/2at^2=velocity x time
Rearranged it into: 3t^2-2vt+40=0
it's in the form ax^2+bx+c=0 So i use the x= -b\pm \sqrt{b^{2}- 4ac}}/2a
I get t= \frac{2v\pm 2v\sqrt{480}}{6}
Another way I tried was:
(velocity of man)=\frac{20+1/2at^{2}}{t}=at (velocity of bus)
20+1/2at^{2}=at^{2}
3t^{2}=40
t^{2}=\frac{40}{3}
t=\sqrt{\frac{40}{3}}
t=3.6515 seconds
therefore distance bus travelled=1/2a(\sqrt{\frac{40}{3}})^{2}=20 metres
therefore man has to travel 20+20=40 metres
therefore velocity of man= 40/ \sqrt{\frac{40}{3}}=10.95 m/s
Is the above correct??
I think there are a couple of mistakes in your calculations.
First with 3t^2 - 2vt + 40 = 0 using the quadratic formula you get: \frac{2v \pm \sqrt{2v^2 - 480}}{6}
you can't just take the 2v^2 out from under the \sqrt{..} so that leaves t as a bunch of stuff.
I'm confused by the math of the second equation, but before that, I'm confused as to what each side is. On the left, which is the 'velocity of man' you have acceleration, but the man is traveling at at a constant velocity which means no acceleration. I'm going to look some more to see if you're trying to say something else but just wrote it wrong.
And just because I haven't found an answer doesn't mean there isn't one. It just means I haven't found one yet.
you can't just take the 2v^2 out from under the \sqrt{ }
Yes the quadratic formula bit was wrong.
As for the 2nd method, what I am trying to say is... the velocity=distance divided by time right?
Okay... so the distance the Man has to travel is 20 metres in addition to the distance the bus traveled in that time i.e. 1/2at^2 and the usage of the acceleration shouldn't make a difference cos acceleration is metres/second/second, and your timesing it by t^2 therefore you have metres as units.
The RHS of the equation i.e. at is the distance traveled by the bus (as there's no initial velocity=0) so that should be correct i think.
Your answers work for the original problem, but when I did it there was no one answer. For example, if t = 2s, v = 13m/s, that works, as well as t=3s, v=11.167m/s. I think without a definite time or velocity, the answer is some sort of curve.
And you're equating velocity of the person to velocity of the bus, but there's no saying that they are or should be equal. Or, you may be using distance of the person to be equal to velocity of the bus, and I don't think that's right either. It's still not clear to me. But let me say, I'm not an expert, just another person learning and trying to help as I go.
Anyone else??
What chocokat did looks correct, you have some info misssing (probably the question wants minimum velocity, which you can find).
  • · Replies 20 ·
