How Far Must Point P Be from Speaker A for Constructive Interference at 400 Hz?
To achieve constructive interference at point P from speakers A and B emitting sound at 400 Hz, the wavelength (λ) is calculated as 0.85 m using the formula λ = v/f, where v is the speed of sound (340 m/s). The condition for constructive interference is given by the equation λ = 2ΔL/(2p-1), where ΔL represents the path difference. The lowest order of constructive interference occurs at p = 1, leading to a path difference of 0.85 m. However, there is a suggestion that the nearest node to speaker A may not correspond to this lowest order, indicating further analysis may be needed.
Firben
Two speakers A and B, sends out sounds at 400 hz
In what distance x between speaker A and the point P is it constructive interference ?
http://s716.photobucket.com/user/Pitoraq/media/Fys2121_zps9a68fef2.png.html
λ = 2ΔL/(2p-1),
v = 340 m/s
f = 400 Hz
λ = 2ΔL/(2p-1),
λ = 340/400 = 0.85 m <==>
lowest constructive interference p = 1
0.85 m = ΔL <==>
0.85 = y - x, where y = (2.5)^2+x^2=y^2 is the distance between P and B.
Is this right ?
That should get you a constructive interference point (node).
I don't think the nearest node to A (i.e., smallest x) occurs for p = 1, though.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 19 ·
