Contact and electromagnetic force
47 replies · 5K views
rudransh verma
1. F, Fn, f are contact force, normal force, friction exerted by one surface over another. If none is zero then-
A. F>Fn
B. F>f
C. Fn<F<Fn+f
D. All
2. If a body of mass m is moving on rough horizontal surface of coefficient mu then the net electromagnetic force exerted by the surface on the body is -
Newton second law.
I don’t know what is contact force. Are friction and normal forces called contact forces? And we have to take the resultant of the two to get the net contact force?
I was going to provide a definition, but the one in Wikipedia is a bit better.
So to find the contact force we need to take the resultant of all the forces since that is what it is, the resultant of all the contact forces acting on body. Gravity is not a contact force but normal forces, and friction all come under contact forces.
What if there is applied force too acting on the body?
What does Newton's second law say?
F=ma. I think if there is Friction there is applied force too. So sum of all the forces will give contact force or will have to leave applied force?
Newton's second law states that ##\sum F = ma##. Not one force. The sum of all forces.
There can be friction without an applied force. A block that slides to a stop, for instance.
So what do you want to say ?
That was incorrect. There can be friction without some other applied force. An example is a block sliding to a stop.
jbriggs444 said:
Newton's second law states that ∑F=ma. Not one force. The sum of all forces.
So a ramp applies a force known as contact force which can be decomposed into normal and friction. It is the force which is present between matter.
haruspex said:
The Wikipedia article gives "Pushing a car up a hill" as an example of a contact force.
I don’t think that’s what it says. It says “where contact forces are at work”
It says: "Pushing a car up a hill ... are some of the everyday examples where contact forces are at work. In the first case the force is continuously applied by the person on the car".
So, yes, it does say pushing a car up a hill is an everyday example of a contact force.
A contact force acting on a body is any force that is applied to the surface by direct physical contact. The only forces I can think of that are not contact forces are gravity, electric and magnetic forces, and virtual (or "fictitious") forces such as centrifugal, inertial, Coriolis...
Yes.
jbriggs444 said:
Yes.
So, f> Fn.
And since F=under root(Fn^2+f^2)
So, F>Fn
And given ans is Fn+f>F. How?
Also F>f, how?
So, f> Fn.
So, F>Fn
Also F>f, how?
Using variable names without saying what those variable names represent. You do this persistently. Please stop. Use your words. Tell us what the variable names represent.
You claim that "f > Fn".
Sure. If by "##f##" you mean the contact force and by "##F_n##" you mean the normal component of the contact force and if we are working on a ramp with a rough surface so that friction ##F_f## is present and is non-zero then the [magnitude of the] contact force ##f## will be greater than its normal component ##F_n##.
But the next words out of your mouth are that ##F=\sqrt{{F_n}^2+f^2}##.
Sure. If by "##F##" you mean the contact force, by "##f##" you mean friction and by "##F_n##" you mean the normal component of the contact force. But this is a different assignment of variable names than in the previous breath.
It is called the fallacy of equivocation.
jbriggs444 said:
Sure. If by "f" you mean the contact force and by "Fn" you mean the normal component of the contact force and if we are working on a ramp with a rough surface so that friction Ff is present and is non-zero then the [magnitude of the] contact force f will be greater than its normal component Fn.
In question it’s already given f is friction , F is contact and Fn is normal. There is no mention in OP of ramp. I think because f=muFn. So f>Fn. But then I thought Mu is between 0 to 1. So I don’t think f>Fn . (This is not asked by the way)
jbriggs444 said:
But the next words out of your mouth are that F=Fn2+f2.
I am unable to mathematically prove how F>f or F>Fn.( I guessed!)
Just checking: you do understand that the question is saying that F consists of the two components f and Fn, yes?
f=muFn
You don't know that. If this is static friction then f is anything up to ##-\mu_sF_n##.
There is no limit to the value of a coefficient of friction, though most are less than one.
Ok! So how do you prove F>f and F>Fn mathematically?
It is seldom educational to prove trivialities.
So you want to prove that the magnitude of the total force ##|\vec{F}|## is greater than both its the magnitude of its frictional component (##|f|##) and the magnitude of its normal component (##|F_n|##), right?
We can take it as a given that ##|\vec{F}| = \sqrt{f^2 + {F_n}^2}##
The square root function is strictly monotone increasing. For any non-negative ##x## and ##y## such that ##x > y##, it follows that ##\sqrt{x} > \sqrt{y}##.
If ##f## (friction) is non-zero, we know that ##f^2## is strictly positive.
If ##F_n## (normal force) is non-zero, we know that ##{F_n}^2## is strictly positive.
It follows both that ##f^2 + {F_n}^2 > f^2## and that ##f^2 + {F_n}^2 > {F_n}^2##
From which it follows both that ##|F| = \sqrt{f^2 + {F_n}^2} > \sqrt{f^2} = |f|## and that ##|F| = \sqrt{f^2 + {F_n}^2} > \sqrt{{F_n}^2} = |F_n|##
However, there is a loophole in the proof. If ##f## is zero (frictionless) then the magnitude of the total force will not be greater than the magnitude of the normal component. Instead, the two will be equal.
Similarly, if ##F_n## is zero (no normal force) then the magnitude of the total force will not be greater than the magnitude of the frictional component. Instead, the two will be equal.
What does that mean?
jbriggs444 said:
If f (friction) is non-zero, we know that f2 is strictly positive.
If Fn (normal force) is non-zero, we know that Fn2 is strictly positive.
It follows both that f2+Fn2>f2 and that f2+Fn2>Fn2
From which it follows both that |F|=f2+Fn2>f2=|f| and that |F|=f2+Fn2>Fn2=|Fn|
Ho
So F>Fn and F>f. Also Fn<Fn+f. So clearly All of these.
But can we also prove F<Fn+f ?
I have started proving: $$-F<-f$$
$$-F<-Fn$$
Adding both $$-F-F<-Fn-f$$
$$-2F<-Fn-f$$
$$2F>Fn+f$$
Can we proceed further?
If you ask for a proof that 2+2 = 4, the result will not be educational. Depending on what you accept as axiomatic, it can be either trivial and uninformative or quite lengthy and ultimately boring.
Huh?
##\vec{F}## (the total force) is, by definition equal to the sum of its components, ##\vec{F_n}## and ##\vec{f}##.
Possibly you want a proof of the triangle inequality? Given the lengths of two sides of a triangle, the length of the third side is no greater than the sum of the other two.
Ok!
But why is F not equal to muFn always and what are the values of mu ? Is it not always from 0 to 1?
Because I recently learned otherwise.
Because there is no reason it should be. For example: what if there is no friction but there is a normal force?
There is no upper limit on ##\mu_s## (coefficient of limiting static friction) or ##\mu_k## (coefficient of kinetic friction). @haruspex has already told you this (Post #16).
By the way, ##\mu_sF_n## gives the frictional force between 2 surfaces when slipping is about to start.
If there is no slipping, the frictional force could be less than this will be less than or equal to this.
Edited.
For kinetic friction, ##|F_{k}|=\mu_kN##.
For static friction, ##|F_{s}|<=\mu_sN##.
If a body is resting on a frictional surface and a horizontal force ##F_h## is gradually applied then while ##|F_{h}|<\mu_sN## there is no movement. Therefore ##F_s=-F_h##.
Please read https://www.physicsforums.com/insights/frequently-made-errors-mechanics-friction/.
Which, that ##F_s## always equals ##\mu_sN## or that ##\mu<=1##, or both?
Where did you learn that from?
Long list of coefficients at https://www.engineeringtoolbox.com/friction-coefficients-d_778.html shows some exceed 1.
For second question in OP, by electromagnetic force do they mean contact force?
Because friction and normal forces all arise through electromagnetism between atoms and molecules.
They arise from electrostatic interactions between electrons in atoms, but those are still surface effects, so count as contact forces. More generally, electromagnetic interactions may be more long range, reaching to the interiors, and then do not count as contact forces.
Edit: $$F_c=\sqrt{{(mg)}^2+{(mumg)}^2}$$
$$F_c=mg\sqrt{1+{(mu)}^2}$$
$$F_c=\sqrt{{mg}^2+{mumg}^2}$$
$$F_c=mg\sqrt{1+{mu}^2}$$
What does ##mumg^2## mean? Are you trying to write ##(\mu mg)^2##, aka "##(\text{mu}\ mg)^2##"
What you have comes out looking like it means ##um^2g^2##.
You also have a problem with ##mg^2## where ##(mg)^2## is intended.
Curly braces in the ##\LaTeX## source are formatting hints only. They do not render in the finished product.
So you are saying ##F_c=mg\sqrt{1+{\mu}^2}##.
Suppose you weigh (mg =) 700N. You are standing (in equilibrium) on level ground. The coefficient of (static) friction between you and the ground is ##\mu_s=0.5##.
What is the contact force ##F_c## acting on you?
Hint: it is not ##700\sqrt{1+0.5^2}##.
Steve4Physics said:
What is the contact force Fc acting on you?
Well It should be 700N since friction is zero(Standing), not ##mumg##
OK, that is correct. Now suppose you weigh 700 N and you stand at rest on a rough plane inclined at 12° relative to the horizontal. What is the contact force on you in this case? Give magnitude and direction.
