Continuety of these functions
  • Thread starter Thread starter transgalactic
    Functions
5 replies · 2K views · last reply
transgalactic
describe the continuety of these functions
http://img233.imageshack.us/img233/6141/76604020ql2.gif
regarding the [] functions i learned this fact
http://img184.imageshack.us/img184/2469/87823960yl2.gif
Since you used "[x]" I was not sure if you meant "floor of x", [itex]\floor(c)[/itex] or "ceiling of x", [tex]\ceil(x)[/itex]. From the I'm second link it appears that you mean the "floor" function.<br /> Yes, [itex]\floor(x)[/itex] is constant between intgers: n-1 from n-1 up to n and n from n to n+1 so it is really only necessary to look at what happens as you approach the integer n from below and above.<br /> <br /> The last one appears to be "piecewise", defined by different formulas for x rational and irrational but there appears to be something written before "[itex]\pi x[/itex] for x rational. Is that "sin"?[/tex]
how to do a limit of this x*1/[x]
i get 0*+infinity
how to solve the splitted
i can't imagine the graph
i can't do a limit
because rational and irrational are infinitely mixed
what to do?
For x any number other than an integer, if x is between n and n+ 1, [x]= n so
x/[x]= x/n and x[x]= xn. It should be obvious that the function is continuous there. For x slightly below n, say x= n-y, x/[x]= n-y/(n-1) and x[x]= (n-y)n-1= xn/xy. For x slightly larger than n, say x= n+ y, x/[x]= (n+y)/n and x[x]= (n+y)n. Are the limits of those, as y goes to 0, the same?
As for [itex]sin(\pi x)[/itex] for x rational, 0 for x irrational, use the fact that [itex]\lim_{x\rightarrow a} f(x)= L[/itex] if and only if [itex]\lim_{n\rightarrow \infty} f(a_n)= L[/itex] for any sequence [itex]{a_n}[/itex] converging to x. In particular, for any number x, there exist a sequence of irrational numbers converging to x so for such a sequence the limit of this sequence will be 0. That means that in order that the limit itself exist at x, we must also have [itex]sin(a_n\pi)[/itex] converge to 0 also. Since sine is a continuous function, it is easy to see that that limit is [itex]sin(\pi x)[/itex]. That is, this function is continuous exactly for those x such that [itex]sin(\pi x)= 0[/itex].
