Can a Positive Continuous Function Integrate to Zero?
A continuous function f defined on the interval [a,b] that is nonnegative can only have an integral of zero if it is identically zero throughout the interval. If f(x) is not zero at some point c in [a,b], then by the continuity of f, there exists an interval around c where f(x) remains positive. This leads to a contradiction, as the integral of a positive function over any interval must be greater than zero. Thus, the only way for the integral from a to b to equal zero is if f(x) is zero for all x in that interval. The proof can be effectively approached using contradiction or contrapositive reasoning.
selenne431
Suppose that f: [a,b] \rightarrow \mathbb{R} is continuous and f(x) \geq 0 for all x \in [a,b]. Prove that if \int^b_a f(x)dx=0, then f(x)=0 for all x \in [a,b].
Attempt
I had attempted to do this problem by contradiction, except I did not understand how to finish the problem. I would appreciate a few helpful hints on this one.
You were right in the fact that a direct proof would be much to hard for this problem, but a contradiction is hard to come up with. See if you can prove it by contrapositive Suppose f(x) doesn't equal zero, however according to your givens it has to be greater than or equal to zero , then it follows f(x)>0. You should be able to apply some calculus knowledge here to help finish off this proof and save the day proving that the integral of f(x)dx from a to b is greater than zero as well thus making your contrapositive just and completing your informal proof.
Proof by contradiction is a good way to do this.
Suppose you have a continuous function f such that f(x) is nonnegative and the integral from a to b is 0 AND f(x) is NOT 0 everywhere on [a,b].
You should be able to run into a contradiction.
Hint: Since f is not 0, pick some c in [a,b] where f(c)>0. Let f(c) = w > 0. Then by continuity argue that for some interval around c, f(x) > w/2. Then make a rectangle under the graph.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 20 ·
  • · Replies 17 ·
