Continuous Function: Is There an Open Interval Where f is Monotone?
A continuous function f on R may not necessarily have an open interval where it is monotone. While non-constant functions can exhibit monotonicity in certain intervals, continuity alone does not guarantee this behavior. The Weierstrass function is cited as an example of a continuous function that is nowhere differentiable, highlighting the distinction between continuity and monotonicity. To determine monotonicity, knowledge of the sign of the derivative f '(x) in a neighborhood is essential. Therefore, continuity does not imply the existence of a monotone interval.
sbashrawi
Let f be continuous on R. Is there an open interval on which f is monotone?
I think there is such interval for non constant function but I am really not sure.
You might want to check out the "Weierstrasse function" which is continuous for all x but differentiable nowhere.
In general, no.
Continuity doesn't tell you how the fuction approach it's points. If you knew that f '(x) was either negative or postive around some neighbour of your point then you can say if it is monotone or not.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 20 ·
