Continuously draining tank (constant input\dependant output)
  • Thread starter Thread starter Mike T
    Output Tank
The discussion focuses on modeling the height of water in a bathtub that is being filled and drained simultaneously. The inflow rate is constant, while the outflow rate is proportional to the square root of the water height. Participants emphasize the need to establish a differential equation that relates the net flow to the change in height over time. The relationship between volume and height is clarified, with an assumption made that the bathtub has vertical sides, simplifying the volume calculation. The challenge lies in accurately calculating the net outflow based on the water height and determining the time when the bathtub will overflow.
Mike T
I've been asked to solve a problem where a bathtub is being filled at a constant rate, meanwhile water is draining out continuously. The bathtub fills with a constant flow rate of \frac{dI}{dt} and drains with a flow rate \frac{dO}{dt} which is directly proportional to √h where h is the height of the water.
The question is to come up with an equation describing the height of the water over time, given this constant input and varied output. Use this to find out what time the bath water will overflow.
netflow = \frac{dI}{dt} - \frac{dO}{dt}
3. The Attempt at a Solution
So I've assumed that I should come up with a an equation in the form h(t) where h is the height, and t is the time variable.
I know the volume of the bath, so what height needs to be reached. I've tried integrating both of the flow rates, and then combining them e.g. h = I(x) - O(x), and then solving for the initial condition h = bath height. This gives me the time to fill the bath (although I don't now how accurate it is!) - how I can I make this into a more general solution to find the height at any time t?
I'm having great difficulty relating the input and output in this equation together, and would welcome any points on the general approach, as well as my current approach above.
You need to write down a differential equation. Before you have done that you cannot integrate it properly. How do you relate the net flow to the rate of change in height?
You are given that the bath tub drain at a rate "directly proportional to \sqrt{h}". How do you write that as an equation?
What is the relationship between the volume of water (V) and the height of water (h)? If it is a cylindrical bathtub (with vertical sides) the relationship is just V = Ah, where A = area of base. However, for a bathtub with sloping sides and rounded bottom, etc., the relationship could be a lot more complicated. So, you had better start by stating an assumption about the bathtub's shape.
Then, if r = volumetric inflow rate (which you called dI/dt), what is the volume of inflow in the time interval ##(t,t + \Delta t)##, and what is the volume of outflow during this same interval? What is the NET inflow volume in that interval? (Here, ##\Delta t > 0## is a very small time increment.)
Then, if r = volumetric inflow rate (which you called dI/dt), what is the volume of inflow in the time interval (t,t+Δt)(t,t + \Delta t), and what is the volume of outflow during this same interval? What is the NET inflow volume in that interval? (Here, Δt>0\Delta t > 0 is a very small time increment.)
Hey, thanks Ray - in this case, I'm assuming a bath tub has vertical edges, so the volume is directly proportional to the height helpfully. So in this time period \triangle t the net flow in is r \triangle t.
Calculating the net outflow in this time period is what I'm finding hard as it is dependant on the volume (or height) of the water. Ah, is this where I use the net inflow volume, r \triangle t as the basis for calculating the outflow volume in this time? This makes sense (if I've got it correct!) for a small period, \triangle t, but it wouldn't for a large period. So I need to find the definite integral between v amd max volume?
edit: I mean, integrate from t=0, to t=infinity of course, and then find at what value of t, the volume matches my expected result?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
