Contour integral of e^(-1/z) around a unit circle?
The integral of e-1/z around a unit circle centered at z = 0 evaluates to -2πi, determined using the Laurent series expansion which reveals a residue of -1 at the essential singularity. Despite the presence of infinitely many poles, the singularity at z = 0 is isolated, allowing the residue theorem to apply effectively. The discussion clarifies that the singularity is not a pole but an essential singularity, confirming that the integral's evaluation remains valid.
  • Understanding of complex analysis and contour integration
  • Familiarity with Laurent series and residue theorem
  • Knowledge of essential singularities and their properties
  • Basic skills in evaluating complex integrals
  • Study the residue theorem in complex analysis
  • Learn about essential singularities and their implications
  • Explore the properties of Laurent series in detail
  • Practice evaluating contour integrals with various singularities
Students and professionals in mathematics, particularly those specializing in complex analysis, as well as anyone interested in advanced integration techniques and singularity theory.
CrimsonFlash
What is the integral of e-1/z around a unit circle centered at z = 0?
The Laurent expansion of this function gives : 1 - 1/z + 1/(2 z^2) - 1/(3! z^3) + . . . . .
The residue of the pole inside is -1.
So the integral should be = -2πi
Is this right? Also, aren't there infinitely many poles or infinitely high order of the pole at z = 0?
So what? The residue is enough to find the answer, and it looks right to me.
Remember that the contour integral
$$\oint_{|z| = R} \frac{dz}{z^n}$$
around a circle of radius R centered at the origin is zero for any ##n \neq 1##. You can show this explicitly by the change of variables ##z = \exp(i\phi)##. (You can also show the integral is ##2\pi i## for n = 1 this way).
So, as long as you can exchange the sum with the integral (which you can in this case), all terms but the residue term will integrate to zero.
yeah, you got it right. And yes, it is a pole of infinitely high order (an essential singularity). But this is not a problem. If there were infinitely many poles, then there would be a problem. But you can see for yourself that for this case, the singularity is isolated. Imagine removing the point z=0, then are the other points around it holomorphic?
No. There is not even one pole. Poles are finite-ordered singular points. Rather, the singular point at the origin is an essential singularity with infinite order.
Ok, thanks everyone. Also, can you help me with the following:
f(z) = sqrt(z)/(1+z^2) = sqrt(z)/[(i+z)(z-i)]
The poles of this are at i and - i. The residues I calculate are:
For i := sqrt(i)/(2i) = exp(πi/4)/(2i)
For -i := sqrt(-i)/(-2i) = exp(-πi/4)/(-2i)
Bur WolframAlpha says otherwise. The i shouldn't be there in the denominator. But I can't see how to get rid of them...
1/i = -i, does that help?
And you can evaluate exp(πi/4) if you like.
Never mind, I got what I was looking for.
Thanks anyway.
