Convective heat transfer correlations
  • Thread starter Thread starter arpatil_31
    Heat Heat transfer
The discussion clarifies the differences between constant wall heat flux and constant wall temperature in convective heat transfer correlations. In constant wall heat flux scenarios, the wall temperature increases with distance to maintain a constant heat flux, while in constant wall temperature scenarios, the wall temperature remains fixed and the heat flux can vary. The participants emphasize the importance of boundary conditions in these scenarios and provide insights into the behavior of temperature profiles in pipe flow, particularly how the heat transfer coefficient behaves as flow conditions change.
  • Understanding of convective heat transfer principles
  • Familiarity with boundary conditions in thermal analysis
  • Knowledge of heat transfer coefficients and their calculation
  • Basic equations of fluid dynamics related to heat transfer
  • Study the derivation of the heat transfer coefficient in pipe flow scenarios
  • Research the impact of boundary conditions on heat transfer rates
  • Learn about temperature profile development in convective systems
  • Explore advanced topics in thermal analysis, such as transient heat conduction
Engineers, thermal analysts, and students studying heat transfer principles, particularly those focusing on convective heat transfer in fluid systems.
arpatil_31
What is the difference between constant wall heat flux and constant wall temperature for convective heat transfer correlations?
Hi arpatil_31. Welcome to Physics Forums!
In the case of constant wall heat flux, the temperature at the wall is increasing with distance along the wall, while, in the case of constant wall temperature, the wall temperature is constant. In the constant wall heat flux case, the wall temperature has to increase along the wall in order to maintain the heat flux constant.
It's a matter of boundary conditions, really. As was previously stated, for a constant temperature wall, the wall is held at a constant temperature. For a constant heat flux wall, the derivative of temperature normal to the wall is held constant at the wall.
Thanks Chestermiller and boneh3ad...
OK.
That means for constant wall temperature, wall is held at constant temperature and its heat flux (Heat transfer rate) may change.
But I am slightly confused for constant wall heat flux (For e.g. Hot fluid flows through pipe):Let us consider eqn. q= h x (dT/dy).
For pipe flow at leading edge h is higher and it goes on decreasing then after some time it becomes constant. when h becomes constant the temperature difference should becomes constant by increasing the temperature of the wall to maintain constant wall heat flux.
Am I right? If not then please elaborate it.
OK.
Yes. The temperature difference between the wall temperature and the average fluid temperature becomes constant. The shape of the temperature profile remains constant radially, but the temperature at all radial locations increases uniformly and linearly with distance along the tube as the fluid continues to receive heat. So the temperature becomes a function of r plus a linear function of z. You should be able to use this info to easily derive a simple equation for the asymptotic heat transfer coefficient.
Thanks Chestermiller. Now my doubt is clear.
  • · Replies 34 ·
