Convergence of a series by root test
The discussion revolves around the convergence of the series defined by the expression (n+2)/(n+1) as n approaches infinity. Participants are exploring whether this series converges and if it converges absolutely, referencing the root test and other convergence tests.
  • Participants discuss the application of the root test and the implications of the limit L, with some questioning the relevance of constant and linear terms as n approaches infinity. Others suggest using the nth term test for divergence and express uncertainty about its application.
The discussion is active, with participants sharing their thoughts on various tests for convergence. Some guidance has been provided regarding the nth term test, and there is acknowledgment of differing interpretations of the series' behavior.
There is mention of conflicting results between personal calculations and external tools like Wolfram Alpha, indicating potential confusion or misinterpretation of convergence tests.
train449
Does the series:
sum from 1 to inf. (n+2)/(n+1)
converge? If so does it converge absolutely?
Ratio test for series
I found this series to converge using the root test, (.jpg attached) however wolfram alpha says otherwise.
Your work was fine until you said L=3/4. Remember n is going to infinity, so the constant and linear terms don't really matter.
I agree with wolframalpha.
A much simpler test to use is the nth term test for divergence.
AH Vela you're right. L=1 so the test is inconclusive. I tried the integral test and got infinty so it does diverge, thank you.
@Mark44 I'm not too sure what the nth term test is
The n-th term test is the first test you should always try on a series. It's also probably the first one you learned. It says if the terms don't go to 0 in the limit as n goes to infinity, the series diverges.
Of course! figures I would forget the most basic reasoning. Thank you Vela!
The Nth Term Test for Divergence is simple to use, but in my experience, is often misunderstood by students. If the limit of the nth term of a series isn't zero, the series diverges. This test tells you when a series diverges but it doesn't tell you when a series converges.
thank you, Mark44, I will make good use of it on my upcoming test!
