Convergence of a series by root test
8 replies · 3K views
train449
Does the series:
sum from 1 to inf. (n+2)/(n+1)
converge? If so does it converge absolutely?
Ratio test for series
I found this series to converge using the root test, (.jpg attached) however wolfram alpha says otherwise.
Your work was fine until you said L=3/4. Remember n is going to infinity, so the constant and linear terms don't really matter.
AH Vela you're right. L=1 so the test is inconclusive. I tried the integral test and got infinty so it does diverge, thank you.
The n-th term test is the first test you should always try on a series. It's also probably the first one you learned. It says if the terms don't go to 0 in the limit as n goes to infinity, the series diverges.
Of course! figures I would forget the most basic reasoning. Thank you Vela!
The Nth Term Test for Divergence is simple to use, but in my experience, is often misunderstood by students. If the limit of the nth term of a series isn't zero, the series diverges. This test tells you when a series diverges but it doesn't tell you when a series converges.
thank you, Mark44, I will make good use of it on my upcoming test!
