Convergence of {n/(n^2+1)}: Is it Possible?
  • Thread starter Thread starter mmilton
    Convergence
The sequence {n/(n^2+1)} is convergent, with a limit of 0 as n approaches infinity. This conclusion is supported by applying the rules of limits involving infinity, specifically by rewriting the expression as ((1/n)/(1+(1/n^2))). For sequences, the higher power in the denominator ensures convergence to 0. However, if considering the series formed by this sequence, it diverges, necessitating the use of tests like the Ratio or Integral tests. Understanding the distinction between sequences and series is crucial for accurate analysis.
mmilton
Is the sequence {n/(n^2+1)} convergent, and if so, what is it's limit?
I believe it does converge because the higher power is in the denominator, so thus, it's limit is 0.
Any help or hints on if I'm headed in the right direction would be very much appreciated!
Thank you in advance.
You are right, using the rules you've learned about infinity limits will get us ((1/n)/(1+(1/n^2))) and the limit of that as n approaches infinity is 0.
Multiply the numerator & denominator by 1/n .
If you're talking about the SEQUENCE, then it converges. Use a useful little rule known as L'Hôpital.
If you're talking about the SERIES, use the Ratio or Integral tests. It diverges.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 21 ·
  • · Replies 34 ·
  • · Replies 17 ·
