Checking Convergence of Series: Inequalities & Tests
  • Context: MHB
  • Thread starter Thread starter mathmari
    Convergence Series
The forum discussion focuses on checking the convergence of three specific series using the ratio test and Raabe–Duhamel's test. The first series, $\displaystyle{\sum_{n=1}^{+\infty}\frac{\left (n!\right )^2}{\left (2n+1\right )!}4^n}$, diverges as the limit of the ratio test yields 1. The second series, $\displaystyle{\sum_{n=1}^{+\infty}\frac{1\cdot 3\cdot 5\cdot \ldots \cdot (2n-1)}{2\cdot 4\cdot 6\cdot \ldots \cdot 2n}}$, also diverges due to a calculation error in the ratio test. The third series converges, confirmed by applying the Raabe–Duhamel's test correctly, which provides a clearer method for determining convergence.
  • Understanding of series convergence tests, specifically the ratio test and Raabe–Duhamel's test.
  • Familiarity with factorial notation and its properties.
  • Basic knowledge of limits and inequalities in mathematical analysis.
  • Ability to manipulate and simplify mathematical expressions involving series.
  • Study the Raabe–Duhamel's test in detail to understand its application in series convergence.
  • Learn about other convergence tests such as the root test and comparison test for series.
  • Practice solving convergence problems involving factorials and products in series.
  • Explore advanced topics in series analysis, including power series and their convergence properties.
Mathematicians, students studying calculus or real analysis, and anyone interested in series convergence and mathematical proofs.
mathmari
MHB
Hey! 😊
I want to check the convergence for the below series.
- $\displaystyle{\sum_{n=1}^{+\infty}\frac{\left (n!\right )^2}{\left (2n+1\right )!}4^n}$
Let $\displaystyle{a_n=\frac{\left (n!\right )^2}{\left (2n+1\right )!}\cdot 4^n}$.
Then we have that \begin{align*}a_{n+1}&=\frac{\left ((n+1)!\right )^2}{\left (2(n+1)+1\right )!}\cdot 4^{n+1}=\frac{(n!)^2(n+1)^2}{\left (2n+3\right )!}\cdot 4^{n}\cdot 4=\frac{(n!)^2(n+1)^2}{\left (2n+1\right )!(2n+2)(2n+3)}\cdot 4^{n}\cdot 4 \\ & =\frac{(n!)^2(n+1)^2}{\left (2n+1\right )!2(n+1)(2n+3)}\cdot 4^{n}\cdot 4 =\frac{(n!)^2(n+1)}{\left (2n+1\right )!(2n+3)}\cdot 4^{n}\cdot 2\end{align*}
So we get \begin{equation*}\frac{a_{n+1}}{a_n}=\frac{\frac{(n!)^2(n+1)}{\left (2n+1\right )!(2n+3)}\cdot 4^{n}\cdot 2}{\frac{\left (n!\right )^2}{\left (2n+1\right )!}\cdot 4^n}=\frac{(n!)^2(n+1)\left (2n+1\right )!}{\left (2n+1\right )!(2n+3)(n!)^2}\cdot 2=\frac{(n+1)}{(2n+3)}\cdot 2=\frac{2n+2}{2n+3}\end{equation*}
It holds that $\displaystyle{\left |\frac{a_{n+1}}{a_n}\right |=\frac{2n+2}{2n+3}<1}$.
For the ratio test we have that the limit has to be less than $1$, right? So do we have to apply an other test?
- $\displaystyle{\sum_{n=1}^{+\infty}\frac{1\cdot 3\cdot 5\cdot \ldots \cdot (2n-1)}{2\cdot 4\cdot 6\cdot \ldots \cdot 2n}}$
Let $a_n=\prod_{i=1}^n\frac{2i-1}{2i}$ then $a_{n+1}=\prod_{i=1}^{n+1}\frac{2i-1}{2(i+1)}$.
So we get that $\frac{a_{n+1}}{a_n}=\frac{2(n+1)-1}{2(n+1+1)}=\frac{2n+1}{2n+4}<1$
Again the ration test doesn;t help us, does it?
- $\displaystyle{\sum_{n=1}^{+\infty}\frac{1\cdot 3\cdot 5\cdot \ldots \cdot (2n-1)}{2\cdot 4\cdot 6\cdot \ldots \cdot 2n\cdot (2n+2)}}$
Let $a_n=\prod_{i=1}^n\frac{2i-1}{2i+2}$ then $a_{n+1}=\prod_{i=1}^{n+1}\frac{2i-1}{2i+2}$.
So we get that $\frac{a_{n+1}}{a_n}=\frac{2(n+1)-1}{2(n+1)+2}<1$.
The same here. So do we have to fins inequalities at each case or to use an other test? :unsure:
Hey mathmari!
Indeed, we cannot use the ratio test since its limit is 1.
I found the Raabe–Duhamel's test, which appears to work for all 3 of them. 🤔
So do we have the following?
- $\frac{2n+2}{2n+3}=\frac{2n+3-1}{2n+3}=\frac{2n+3}{2n+3}-\frac{1}{2n+3}=1-\frac{1}{2n+3}$
$$1-\frac{1}{2n+3}\leq 1-\frac{b}{n} \Rightarrow \frac{b}{n}\leq \frac{1}{2n+3} \Rightarrow 2bn+3b\leq n \Rightarrow (1-2b)n\geq 3b \Rightarrow n\leq \frac{3b}{1-2b}$$
There is no $b>1$. So it diverges.
- $\frac{2n+1}{2n+4}=\frac{2n+4-3}{2n+4}=\frac{2n+4}{2n+4}-\frac{3}{2n+4}=1-\frac{3}{2n+4}$
$$1-\frac{3}{2n+4}\leq 1-\frac{b}{n} \Rightarrow \frac{b}{n}\leq \frac{3}{2n+4} \Rightarrow 2bn+4b\leq 3n \Rightarrow (3-2b)n\geq 4b$$ We choose $b=\frac{5}{4}$, then $n\geq 10$
So it converges.
- $\frac{a_{n+1}}{a_n}=\frac{2(n+1)-1}{2(n+1)+2}=\frac{2(n+1)+2-3}{2(n+1)+2}=\frac{2(n+1)+2}{2(n+1)+2}-\frac{3}{2(n+1)+2}=1-\frac{3}{2(n+1)+2}$
$$1-\frac{3}{2(n+1)+2}\leq 1-\frac{b}{n} \Rightarrow \frac{b}{n}\leq \frac{3}{2(n+1)+2}\Rightarrow \frac{b}{n}\leq \frac{3}{2n+4} \Rightarrow 2bn+4b\leq 3n \Rightarrow (3-2b)n\geq 4b$$ We choose $b=\frac{5}{4}$, then $n\geq 10$
So it converges. Is everything correct? :unsure:
What did you calculate? 🤔
You already had that $\frac{a_{n+1}}{a_n}=\frac{2n+2}{2n+3}$.
In the link that I posted, I found that we need to calculate $b_n=n\left(\frac{a_n}{a_{n+1}}-1\right)$.
So in this case we have $b_n=n\left(\frac{2n+3}{2n+2}-1\right)=\frac{n}{2n+2}\to \frac 12$.
Since the limit is $\frac 12<1$, it follows that the series indeed diverges. :geek:
So it converges.
It seems you have $\frac{a_{n+1}}{a_n}=\frac{2n+1}{2n+4}$, but I don't think that is correct.
I think there is a mistake in the post where you calculated it. :eek:
I found that it should be $\frac{a_{n+1}}{a_n}=\frac{2n+1}{2n+2}$.
So it converges.
I don't know which calculation method you used. (Wondering)
Anyway, I calculated $b_n=n\left(\frac{a_n}{a_{n+1}}-1\right)=n\left(\frac{2n+4}{2n+1}-1\right) = \frac{3n}{2n+1}\to \frac 32$.
Since the limit is $\frac 32 >1$, it follows that the series indeed converges. :geek:
Ahh I used the following part of your link:
An alternative formulation of this test is as follows. Let $\{ a_n \}$ be a series of real numbers. Then if b > 1 and K (a natural number) exist such that ${\displaystyle \left|{\frac {a_{n+1}}{a_{n}}}\right|\leq 1-{\frac {b}{n}}}$ for all n > K then the series {an} is convergent.
So is it better to use the other formulation? :unsure:
Aha. I actually did not read that far. :geek:
Now that I look at it, it seems indeed to me that the first formulation with $b_n$ is easier to apply and easier to understand and verify.
Either way, I just checked, and I can see now that your calculations and conclusions for the first and third problem are correct.
That leaves the second problem that I believe has a calculation mistake in $\frac{a_{n+1}}{a_n}$. Consequently the series diverges instead of converges. 🧐
Ahh yes!
So we have the following:
Let $\displaystyle{a_n=\prod_{i=1}^n\frac{2i-1}{2i}}$ .
Then $\displaystyle{a_{n+1}=\prod_{i=1}^{n+1}\frac{2i-1}{2i}}$.
So we get $\displaystyle{\left |\frac{a_{n+1}}{a_n}\right |=\frac{2(n+1)-1}{2(n+1)}=\frac{2n+2}{2n+2}-\frac{1}{2n+2}=1-\frac{1}{2n+2}}$
We have that \begin{equation*}1-\frac{1}{2n+2}\leq 1-\frac{b}{n} \Rightarrow \frac{b}{n}\leq \frac{1}{2n+2} \Rightarrow 2bn+2b\leq n \Rightarrow (1-2b)n\geq 2b \Rightarrow n\leq \frac{2b}{1-2b}\end{equation*} Thereisno such a $b>1$, so the series doesn't converge, right? :unsure:
Yep. (Nod)
Yep. (Nod)
Great! Thank you! 😊
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 16 ·
