Convergence or Divergence of Factorial Series
The discussion revolves around the convergence or divergence of the series formed by the reciprocals of factorials, specifically the series 1/n!. Participants explore various methods to determine convergence, including the ratio test and comparisons with other series. The conversation also touches on the broader question of whether all factorial series converge.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • One participant inquires about the convergence or divergence of the series 1/n! and expresses difficulty using the integral test due to the factorial.
  • Another participant suggests using the ratio test to determine convergence.
  • Some participants report using the ratio test and conclude that the series is convergent, while questioning if all factorial series are convergent.
  • One participant asserts that any series summing reciprocals of distinct factorials converges, citing that it is bounded by the sum of all such series, which equals e.
  • Another participant proposes using the Taylor series for e^x or comparing 1/n! with 1/n^2 to demonstrate convergence.
  • A later reply introduces the series Σ(n^n/n!) as a counterexample, indicating that not all factorial series converge.
  • Another participant agrees that the sequence n^n/n! diverges, suggesting that it cannot be summed.
Participants express differing views on the convergence of all factorial series. While some assert that all series summing reciprocals of factorials converge, others provide counterexamples that challenge this notion, indicating that the discussion remains unresolved.
Some methods proposed for determining convergence, such as the ratio test, may depend on specific conditions or comparisons that are not fully explored in the discussion. The implications of the counterexample provided are not fully analyzed, leaving the question of convergence for certain factorial series open.
This discussion may be useful for students and educators in mathematics, particularly those interested in series convergence, factorials, and related mathematical tests.
Christian M.
How can I find out if 1/n! is divergent or convergent?
I cannot solve it using integral test because the expression contains a factorial.
I also tried solving it using Divergence test. The limit of 1/n! as n approaches infinity is zero. So it follows that no information can be obtained using this test.
Is there any way that I can prove its divergence or convergence?
I used the ratio test and got zero as the final answer. So, this means that the given factorial series is convergent.
Just for a follow-up question, is it true then that all factorial series are convergent?
If you are asking about any series summing reciprocals of factorials, the answer is yes as long as they are all different, since any such series is bounded by the sum of all of them (which = e).
You can use either ratio test or Taylor series for ##e^x ## at ##x=1 ##, as proposed already , or the comparison of ##1/n! ## with ##1/n^2 ##, noticing that for n>3, ##n!>n^2 ##
Take a look at [tex]\Sigma\frac {n^n}{n!}[/tex].
Obviously not. The sequence [itex]\frac{n^n}{n!}[/itex] itself diverges, so there is no way you could sum it.
  • · Replies 17 ·
