Converting an algorithm into an equation
  • Context: Undergrad
  • Thread starter Thread starter aw_barron
    Algorithm
7 replies · 5K views
aw_barron
Hello. I've got a simply ballistics program with a very simply algorithm to deal with air friction. However, I am trying to find a mathematical forumula equivalent. Here is the algorithm:
G = accel due to gravity (universal constant)
F = projectile air friction factor (constant for a given projectile)
T = delta T (delay between loops, varies depending on frame rate but is about 0.01)
Projectile starts out traveling at velocity Vo fired at angle Ao.
Velocity is broken into a vector made up of: Vx and Vy
Loop
Ax = Vx * F
Ay = Vy * F * G
V = [Vx*Ax*T, Vy*Ay*T]
Wait T
goto Loop
For any given projectile, I will know Vo and F.
For now, I want an equation where I can specify a point (x,0), and it will give me the required Ao so that the trajectory intersects that point.
Basically, given a specific distance, I want to know the angle required in order to land the projectile there (assuming the ground is flat and projectile is fired from y=0).
I the approach I'm trying to take is to find equations that give the projectile's current position (x,y) based on the variables Vo, Ao, and F, and the constant G. I can do this easily in an Excel spreadsheet, but I'm not sure how to do it in an equation.
I've come up with an acceleration forumula: Ax = Vx^2*F
Basic physics says that velocity is the integral of acceleration. However, I'm confused about if/how I can integrate this, since acceleration depends on velocity.
Can anyone help me out here? Thanks!
Hmm... did I post this in the wrong forum? Do I need to provide more information on my problem? Or maybe I am just expecting a reply too quickly?
If you want to include friction I don't think there is an easy solution to the equations of motion and you must, as you have done, solve the problem numerically. Without friction, there is an easy solution, which you prabably will be able to find using conservation of energy, or solving the (differential) equation of motion.
You can also set op a differential equation (much like the program you encoded) including friction, but you will probably find no 'easy' solution.
Your algorithm makes little sense. In particular, Ay = Vy * F * G should almost certainly be something like Ay= G- Vy*F. Then you would have the differential equation
[tex]\frac{d\vec{V}}{dt}= \vec{G}- F\vec{V}[/tex]
where [itex]\vec{V}[/itex] is the vector with components Vx and Vy and [itex]\vec{G}[/itex] is the vector with components 0 and G.
Assuming that the coefficient F is positive, the correct algorithm should read:
Code:
Loop
Ax = - Vx^2 * F
Ay = - Vy^2 * F - G
V = [Vx + Ax * T, Vy + Ay * T]
Wait T
goto Loop
(where deceleration due to air friction is taken as proportional to square of velocity, as the OP properly mentions afterwards).
As for finding the elevation Ao which gives desired range x, why not do it numerically as well? Just wrap another loop around this algorithm, which guesses the angle by bracketing/bisection search. For that you also need to detect inside the algorithm when the shot dips below level (use x = x + Vx * T, y = y + Vy * T as position updates).
Chusslove Illich (Часлав Илић)
Thanks for the replies! It's been years since I've taken any math, so my terminology is all incorrect. I definitely didn't show you what was a vector and what was a number, so I understand why it didn't make sense. caslav.ilic is correct in his posting of the algorithm.
I'll post from my code:
// simple air friction
Vector3 accel=_speed*(_speed.Size()*_airFriction); //accel = velocity * (magnitude of velocity) * airfriction
accel[1] -= Type()->_coefGravity * G_CONST; //subtract G from vertical component of velocity
_speed += accel*deltaT; //adjust velocity by accel * loop delay
And the variables:
_airFriction = depends on projectile type (default -0.0005)
_coefGravity = 1 in this case
_speed = vector representing current velocity of projectile in 3 dimensions
My goal is to calculate or estimate, BEFORE the shot is taken, what angle the projectile needs to be fired in order to hit the ground X meters in front of it. Basically your classic high school physics problem, only with simple air friction.
I wanted to have a formula, rather than another loop before hand that guesses/checks, for a number of reasons, mainly processing speed.
Hopefully that made things a little more clear. I do appreciate the help!
It seems to me that the minus sign is still missing here. If you observe the shot trajectory, it should cover more ground distance before it reaches peak altitude, then on the way down.
Well, the formula is kind of hard to get, I'm not sure it can be obtained. The square of velocity makes it a non-linear ODE (like in HallsofIvy's post, only with square drag term).
But it shouldn't take much CPU time to do it numerically (of course, you wouldn't do the wait part of the loop here), something in the order of few millisec. Though, of course, it depends on what speed you really need. At worst, you could simply precompute ranges for, say, each 0.1 degree of elevation, and then linearly interpolate elevations for requested ranges when taking shots -- this would already run in a matter of few microsec.
