Converting angual velocity to linear velocity
3 replies · 4K views · last reply
crybllrd
An astronaut is being tested in a centrifuge. The centrifuge has a radius of 10m and, in starting, rotates [tex]\theta[/tex]=0.30t[tex]^{2}[/tex], there t is in seconds and [tex]\theta[/tex] in radians. When t=5.0s, what are the magnitudes of the astronaut's (a) angular velocity, (b) linear velocity, (c) tangential acceleration, and (d) radial acceleration?
Kinematics equations
For (a), I used [tex]\theta[/tex]=.30(5)[tex]^{2}[/tex]=7.5rad, plugging in 5.0s for t. Then knowing initial angular velocity = 0, time = 5s, and now [tex]\theta[/tex]=7.5rad, I used a kinematics equation to determine final angular velocity to be 3rad/s.
Part (b) is where I'm stuck. I was thinking to convert 3 rad/s to degrees, then divide by 360 degrees to get 4.7 rotations a second, but not sure where to go from there (or if I'm on the right track).
Thanks for the fast reply.
Where does that leave me in units? Seems like it would be (rad*m)/s. Is there a way I can divide out the radians?
a radian is the ratio of arc length to radius so essentially, you can leave out the radian with no consequence.
