Converting Boolean expression to miniterms form
frank1
I need to obtain the minimum second order circuit of the function:
Boolean expression: F(A,B,C) = ABC with a bar over C, plus C with a bar over A, plus B, i.e. F(A,B,C) = AB̄C + C(Ā+B).
I know that in order to get the minimum second order circuit, I need to use K-Map using both miniterms and maxiterm and compare them. My problem is to put the expression in it's miniterms form.
Boolean expression F(A,B,C) = AB̄C̄ + CĀ + CB̄, with overbars on some variables, printed on a white background.
Boolean expression F(A,B,C) = ABC' + C(A'+B), with C overlined in the first term and A overlined in the second term.
Boolean expression written as F(A,B,C) = AB̄C̄ + CĀ + CB, with complemented variables shown by overbars.
Can you show us what your K-Maps look like?
but how can I show you my K-maps if I don't have my function in a miniterm or maxiterm form?
Just draw the 2x4 K-Map and map the 1's for the function you have listed. There is one simplification that comes out of doing this...
Ok, got it.
Its possible to draw the K-map because where is C.B for example, I can map 1's in the cells adjacents where only A changes.
thanks
frank1 said:
Ok, got it.
thanks
Good job! :smile:
