Converting cartesian unit vectors to spherical unit vectors
7 replies · 25K views · last reply
kde2520
Well, it's all in the title. I just need to show that Gauss's theorem applies to this fluid flow and have converted all my (x,y,z) components to their respective (r,theta,phi) versions, but I can't remember the spherical counterparts of [tex]\hat{x}[/tex],[tex]\hat{y}[/tex],[tex]\hat{z}[/tex].
Wouldn't it have been easier to look at the page you linked to and see that there is no direct conversion there than to assume that I didn't already do that and reply to my post?... maybe not. Thanks though.
I thought you wanted [tex]\hat{r}, \hat{\theta}, \hat{\phi}[/tex]. I would call those the "spherical counterparts" of the cartesian basis vectors. What do you want?
You're right, I didn't word it very well. Here's what I was trying to compute:
[tex]\vec{u} \cdot d\vec{A}[/tex]
where
[tex]\vec{u} = (2xy^{2}+2xz^{2})\hat{x} + (x^{2}y)\hat{y} + (x^{2}z)\hat{z}[/tex]
and
[tex]d\vec{A} = r^{2}sin\theta d\theta d\phi \hat{r}[/tex].
I first converted the magnitudes of [tex]\vec{u}[/tex] to spherical coordinates, and what I intended to do was convert [tex]\hat{x}, \hat{y}, \hat{z}[/tex] to spherical as well. Does that make sense?
Anyway, I ended up using [tex]\hat{r} = sin\theta cos\phi \hat{x} + sin\theta sin\phi \hat{y} + cos\theta \hat{z}[/tex], leaving the unit vecors in the cartesian basis.
But then when I tried to compute the scalar product I ended up with a virtually unintegratable expression. The left side of the equation (remember I was trying to show that Gauss' theorem holds over a spherical region [tex]a^{2} = x^{2} + y^{2} + z^{2}[/tex]) came out to [tex]\frac{8}{3} \pi a^{5}[/tex].
Do you think I was setting it up right? I was thinking that I probably skrewed up some algebra while computing the dot product.
If you are integrating over a sphere of radius a, then the normal vector is (x*xhat+y*yhat+z*zhat)/a. Does that suggest any simplifications? Sorry, it's kind of late here so I haven't really thought this through.
Another tip. Once you have your x,y,z expression for the integrand. You can choose the axis of the spherical coordinate system to point along any cartesian axis.
When I converted Laplacian from cartesian to spherical I use these unit vectors. I think my weblog will be usefull for you.
http://buyanik.wordpress.com/2009/05/02/laplacian-in-spherical-coordinates/"
