Converting English to Boolean Algebra
The discussion focuses on converting a logical statement about an irrigation system into Boolean algebra. The correct representation of the conditions is established as Z = A(B' + C'), where A represents the system being enabled, B' indicates not raining, and C' signifies not freezing temperatures. Participants clarify that "nor" implies an addition operation in Boolean terms, leading to the conclusion that the valve should open when the system is enabled and either not raining or not freezing. The use of DeMorgan's law is acknowledged as helpful in understanding the relationship between the conditions. The final agreement confirms the accurate formulation of the Boolean equation for the irrigation system's operation.
Nyasha
An irrigation system should open sprinkler's water valve when if the system is enabled and neither raining nor freezing temperatures are detected.
S\rightarrow system enabled
R'\rightarrow not raining
F'\rightarrow freezing temperatures not detected
F=S+R'F'
F=S+(RF)'
Guys l do not know if my Boolean equation is correct.
What are V and N?
Note there are 3 conditions (S, R', and F'), all of which must be true.
Redbelly98 said:
What are V and N?
It was actually supposed to be :
F=S+R'F'
F=S+(RF)'
So is this the correct equation ?
An irrigation system should open sprinkler's water valve = Z
when if
the system is enabled = A
and
neither raining = B'
nor freezing temperatures are detected. (same as or not freeze...) = C'
Z = AB' + C'
as defined above the and is multiplication, the or is addition
if it says not, neither or something like that its the compliment
when if
and
Z = AB' + C'
So does "nor" mean that l should add the addition operation ? Would this be correct:
Z=A(B'+C') ?
Z=A(B'+C') ?
I'm not sure if "+" means "and" or "or", so I'll just say it should be all and's, and no or's, in the statement.
I.e., there are 3 conditions A, B' and C', all of which must be true: A and B' and C'.
Isn't the sprinkler's water valve supposed to open when system enabled and not raining or when the system is enabled and not freezing temperatures ?
F=A(B'+C')
F=AB'+AC'
"+" means or
"*" means and
' means NOT
"neither raining nor freezing" means:
(Not raining) AND (Not freezing)​
which is equivalent to
Not (raining or freezing)​
I know understand. You used Demorgan's law
B'C'=(B+C)'
Thanks very much for the help
16K
21K
  • · Replies 102 ·
11K
  • · Replies 175 ·
26K
