Converting from 2D coordinate Systems
This discussion focuses on converting between two 2D coordinate systems using transformation matrices. The user identified corresponding points in both systems and formulated the equation A*x = u, where A represents the transformation matrix. The user inquired about the conditions under which A is a valid transformation matrix and sought alternative methods for determining transformation matrices. MATLAB was mentioned as a tool for solving the equation using the approach A = u*inv(x).
  • Understanding of 2D coordinate systems
  • Familiarity with transformation matrices
  • Basic knowledge of MATLAB programming
  • Concept of matrix inversion
  • Research the conditions for a valid transformation matrix in 2D space
  • Explore alternative methods for calculating transformation matrices, such as least squares fitting
  • Learn about MATLAB's built-in functions for matrix operations
  • Investigate image processing techniques that utilize coordinate transformations
This discussion is beneficial for image processing professionals, data analysts, and anyone involved in geometric transformations within 2D coordinate systems.
quasi426
I am trying to get from one 2D coordinate system to another 2D coordinate system. I found 2 corresponding points and each system. I did the following:
[a1 a2 ] * [ x1,y1 ] = [u1,v1]
[a3 a4] [ x2,y2] [u2,v2]
or A*x = u
if I use MATLAB to solve A = u*inv(x)
when will A be a valid transformation matrix?
Are there other methods to find transformation matrices?
This is not a homework question, I'm just doing some image processing and just need some help.
  • · Replies 30 ·
  • · Replies 34 ·
