Converting revolutions per minute to rad/s for angular acceleration
12 replies · 4K views
notsam
A dentist’s drill starts from rest. After 3.07 s
of constant angular acceleration, it turns at a
rate of 24400 rev/min.
Find the drill’s angular acceleration.
Answer in units of rad/s2.
F=mv^2/r, vi=vf+at, a=v^2/r
The part that I don't understand is how 2440 rev/min is related to the other units. If I knew this I could probably solve it.
how many radians will be covered one revolution ?
just put that and use 60s for 1min .. you'get speed in rad/s
And rads/sec can be used as a velocity?
rad/s is angular velocity... 2(pi) rad = 1 rev i believe
use eqn of on velocity not linear velocity to solve this question
w = wo + αt
Thanks! This isn't part of the homework but I am curious because my teacher said that it would be on the test, what if I wanted to find the angle that the drill rotates? Since I have 24400 rev/min = 2555 rad/sec over an interval of 3.07 s, I would multiply 2555 x 3.07 which would give me radians and then convert it to degrees?
all the Newton eqn's are valid for rotation in angular form
2555 x 3.07 will not work as you have acceleration
Try this:
θ = wot + 0.5αt2
Which come from
s = ut + 0.5at2
*just use:
s = θr
v = wr
a = αr
for all Newton eqn to convert them to rotation one ! :)
No way? So when it's at rest it simplifys to s=.5at^2? And s= arc legth in radians?
notsam said:
No way? So when it's at rest "initially" it simplifys to s=.5at^2? And s= arc legth in radians?
length cannot be in radian ... rad is a pure number .. length is in meters
Ok so the basic kinematic equation for distance can also be used for angles when using angular acceleration. That is SO helpful that just opened up a door in my mind I understand this matertial so much more now!
Yes they can be
i already gave you 2
last one is : w2 = wo2 + 2αθ
2555 rads/sec is the final velocity after 3.07 seconds of constant acceleration.
